  New Posts New Posts RSS Feed - Engine build opinions?
 Post Reply Post Reply Page    <1 234
TX Foilhead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: March-26-2013 at 5:00pm
The tranny would be that much work, the Vdrive has about 3 times the hoses though. That ones pretty easy to talk myself out of because I would have to pull the backseat, panel and floor to show it off. I did have some floor epoxy color matches to silver cloud for the bilge. Hopefully it will go on pretty smooth and I won't have to sand and polish to make it shine which is why I passed on the gel.
77 SKI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 77 SKI Quote  Post ReplyReply Direct Link To This Post Posted: May-17-2013 at 5:11pm
It's alive! I had a lot of problems with the carb, turns out the manifold tilted the carb too much. A wedge plate took care of that. Well and setting the timing 180 off. Runs awesome now, but the motor cover doesn't fit too well. The exhaust manifolds are a little too wide. I can get it on, but will have to fiberglass in some small pockets. I might wait till winter. Don't tinkering for now.
She sounds good!! Just a little thump and perfect exhaust note. Not too loud, not too quiet!
1977 Southwind 18
1994 Ski
1997 - 2008 Ski (Promo)
1977 Ski (current)
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: May-17-2013 at 5:53pm
Which way did you tilt the carb, and how much, I can see the tilt on mine too,my motor sits pretty flat in the boat. With the engine being backerds I might need to go the opposite way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-17-2013 at 6:23pm
Check out Joe in New York's engine box modification. He was able to reuse the upholstery after making pockets for his hiteks- pretty slick. I cut my box in half and widened it- no saving my vinyl.
Did you open it up yet? Gotta be a 53mph boat, I would think.
Really looking forward to checking this boat out at GL.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 77 SKI Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2013 at 10:41pm
She runs awesome. The only issue I have is it will run 5900 rpms. I have the acme 540 and not sure if I should re-prop, but at what point is too many rpms on the 351. The rings and bearings looked new, so we didn't tear it down completely.
I backed out of the throttle as it hit 5900 rpms. I know if I stayed in it, it will hit 6000 plus. What do you guys think?
1977 Southwind 18
1994 Ski
1977 Ski (current)
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2013 at 10:51pm
What was your speed?
Did it level off at some point or was it still pulling all the way to 5900?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 77 SKI Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2013 at 11:21pm
the airguides only go to 50 and they were pegged. I backed out before it hit 6. It was still pulling.
1977 Southwind 18
1994 Ski
1977 Ski (current)
65 'cuda View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 65 'cuda Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2013 at 11:55pm
acme 430.
GlassSeeker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: May-21-2013 at 4:47am
why didn't you stay in it? chicken?
This is the life
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-21-2013 at 6:38am
Double check the RPM's with a shop tach.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-21-2013 at 7:44am
I agree with Pete. The numbers you're claiming are a good bit beyond what we've come to expect from this combo. Verify the tach is correct and get a GPS on the thing. Alan's 55mph 380hp '81 ran 5800 or so with the 540 and required a 430 to get the revs back down, but I don't think you're quite at that power level.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 77 SKI Quote  Post ReplyReply Direct Link To This Post Posted: May-21-2013 at 11:45am
I haven't verified the tach. Not sure how too, but I don't have any reason to think it isn't right. The speedos we set by gps. I have not dynoed the engine, but i do know, its running between 5800 and 5900 before I backed it out. I just don't think I should bew running that close to 6000 WOT. That was with three in the boat too.
1977 Southwind 18
1994 Ski
1977 Ski (current)
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-21-2013 at 12:27pm
It's possible that you have a fast hull that's giving you a higher top end than is typical with the gt40/gt40p upgrade, but I'd be darn sure that's the case before re propping. Get a shop tach and compare it to yours and see how close they are. If original, I wouldn't put much faith in the old Teleflex. Also get a GPS on the thing. If you're doing 53, tht alone would make me think the tach is lying. If its 56-57, that's something else altogether.
While I wouldn't spin the thing to the moon, going to a larger prop puts more stress on the engine and tranny, so keep that in mind.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 77 SKI Quote  Post ReplyReply Direct Link To This Post Posted: May-21-2013 at 1:55pm
Hell, I'll just leave the 540 on it. Easier on everything. I just get spooked when the tack is around 6 on a 36yr old engine. It sure sounds nice. I need to check the gps and let you know.
Thanks for all your input. I pretty much did what everyone on this forum said to do and it runs like a champ.
Now if I can find that loudmouth with the new mastercrap!
1977 Southwind 18
1994 Ski
1977 Ski (current)
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-21-2013 at 2:06pm
Don't get me wrong- if that 6k rpm is legit, I'd be looking at a 430. I just wouldn't necessarily believe it without better data. If, in reality, you're closer to 5500, then the 540 is probably what I'd keep on there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-21-2013 at 10:03pm
I really would not trust the Teleflex from 1977.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2013 at 12:29pm
I have to agree with these guys sounds a bit high with your build add-on's.
With the 1:1 the GPS will tell if the tach is good or not.
