Help with various wiring.. |
gR@HaM
Posted: June-03-2013 at 9:51am |
Refitting the wiring loom to my Tique there are quite a few connections Im not 100% sure of, Ive looked at a couple of wiring diagrams regularly posted on CCF but they dont seem to be the same as I have.
Also.. I do have a multimeter but am not very electronically inclined!! Alternator: Does this look right? The wires Ive reconnected are the thick orange (probably origionally red) going to +ve, and the black wire at 11 o'clock I set to ground. The green:yellow connector was pretty self explanatory even for me! Fuel tank: There was origionally 4 wires running to the transom, 2 of which for the blower - this im looking to relocate to the engine. The other two, red and black Im guessing are +ve and ground for the fuel tank? Should the fuel filler (chrome plated) also be earthed? Thats it for now, although for sure I shall have plenty of other doubts! Normally Im quite happy to try to 'wing it' with these things, but when it comes to electrics I dont want to burn anything out resulting in more expense.. or even worse set the b******* engine on fire when Im out on the water!! |
'82 Ski Tique
baitkiller
Wires in the back: Pink is fuel sender, yellow should be blower power. Yes ground the tank (separate from the sender) and deck fill to DC ground.
