trans oil cooler |
gR@HaM
Posted: June-03-2013 at 6:57pm |
'82 Ski Tique
TX Foilhead
Mine is same as the coil bracket and I bolted it to the outside bolt hole on the back of the head. Not sure thats right, but it works. Mine came with a twisted coil bracket and didn't have enough hose to reach a suitable spot, I just got a new straight bracket and added enough hose to get it to the closest place.
cphase
Gold Member Joined: May-11-2010 Location: Newnan, GA Status: Offline Points: 795 |
The oil flow direction needs to be opposite to the water flow direction.
I hope this makes sense |
Grahan, Chris is correct. The direction of flow maintains the max delta T keeping the efficiency of heat transfer high. So, you will want to feel the oil cooler from the starboard side per your picture. |
gR@HaM
Thanks, yep makes perfect sense.. other than the fact that I dont understand direction of flow with the trans oil hoses!! |
'82 Ski Tique
gR@HaM
Noted.. so I connect the side of the oil coller without the drain plug to the hull. Simples |
'82 Ski Tique
