  New Posts New Posts RSS Feed - Stringer Job
Stringer Job
Jaxboater View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jaxboater Quote  Post ReplyReply Direct Link To This Post Topic: Stringer Job
    Posted: June-26-2013 at 3:02pm
Good afternoon all, i got my boat up and running like a champ now.... then i noticed behind my engine there are two "stringers/ boards going left and right" that the fiberglass covering is coming off and i can see a little bit of the wood. Does anyone know how much this would normally cost to repair? i have been reading all of the Stringer replacement conversations and it seems so complicated i thought id ask how much it would cost to have someone repair them.
JaxNole
1979 Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2013 at 3:54pm
Jax - To have someone do a decent job would be $4000+.
Essentially, economics suggest either do the repair yourself or use the boat 'as is' until it is no longer seawortthy & then part it out.
ny_nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ny_nautique Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2013 at 4:06pm
It sounds like you're talking about the crossbar that spans the main stringers. This is used to support the rear removable floor. However, I didn't think there were 2 of them in a 79.
If they are coming off, it is likely you have delamination somewhere else.
Can you post pictures?
It should be easy to repair yourself. How handy are you?
- Jeff
1999 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jaxboater Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2013 at 1:41am
Well guys I have received a lot of great advice here and have the boat running awesome. It was willed to me by a friend who had it in a storage unit for like 20 years.
I am handy but am a little nervous cutting, and sanding into the boat...
Here is what I found.
Behind the engine block, the supports that run left and right. "not stringers but what comes off them". had the coating coming off, so I took a peak behind the coating to see whats up and found some rotten wood. I have been all over the net reading about these and it seems do-able for me but I wanted some good insight or advise how to do it.
I am going to take pics Saturday- don't know how to post them but will try.
I really do not want to sell it after all I have done to the boat and how it was willed to me, but if its going to cost me $$$$ I would actually consider selling . which im trying to avoid.
JaxNole
1979 Tique
Post Options Post Options   Thanks (1) Thanks(1)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: June-29-2013 at 9:37am
If you can cut wood & paint with a brush, you have the skills needed to do this.
Referencing my earlier post, you can have someone repair that single spot for a few hundred, but most likely the rot goes deeper.
