  New Posts New Posts RSS Feed - 1993 Ignition Problems
93Sport View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 93Sport Quote  Post ReplyReply Direct Link To This Post Topic: 1993 Ignition Problems
    Posted: July-01-2013 at 2:33pm
I am having a problem with Standard 351 PCM engine. When engine is run under load for 10-15 minutes, it starts to miss. I have replaced the Carb for another problem and it starts, runs, accelerates, idles, etc as it should. After running under load (cruising @2200 RPM) it starts to miss, and last time out finally dropped down to 1000RPM@ WOT. Just before last outing, I did research here and decided it was probably coil. The resistor had been by-passed by a previous owner, so I replaced it with an standard Ford oil filled, internal resistor coil. I am not sure what Distributor I have. I think it is a points Prestolite which has been converted to EI. Please look at pictures and see if that is correct. It has 2 wires to Distributor. 1 to 12 volts and the other to the - side of the coil. I also fabbed up a bracket to stand coil up. I have read a lot (probably not all) of the previous posts having to do with Coils and Distributors, but most do not fail only when hot. The coil was extremely hot after the last run. The engine operating temp is about 145°-155°. Would this be a characteristic of a failing ignition module in the Distributor.
Any suggestions are appreciated.
TX Foilhead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2013 at 4:01pm
Sounds like a coil problem and looks like your on the right track. Thats a Prestolite dizzy with points.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2013 at 4:10pm
Correction- thats a Prestolite dizzy with a PCM (Prestolite) EI kit installed.
Also check your pick up to trigger gap on the EI.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 93Sport Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2013 at 4:27pm
Does anyone have specs for the gap? I have no documentation for this install. It does not look the same as the current models.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2013 at 4:54pm
Is it .100?? It's been a while. You could confirm that with a google search. Those ever-so-helpful MasterCraft forums might also have the answer.
I have a Prestolite kit in my boat as well but a MSD Blaster coil. I know the ballast resistor is still in play but not sure if its only online for the coil and bypassed for the distributor or is still serving both. I want to say both. I have been meaning to take a closer look at it and measure the resistances, will hopefully get to it over the weekend and report back.
You can't expect to bypass your stock coil with any of these kits and not expect it to fail.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2013 at 6:45pm
.010 inch, use a non-ferrous (brass or stainless) feeler gage.
HW, '79 told me that the Prestolite EI doesn't need a ballast resistor, so I took it out of the circuit.    All you need to do is move the hot wire terminal to the other side of the resistor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 93Sport Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2013 at 6:59pm
I think that the person who installed the conversion on my engine did as you suggested, but he fed the distributor off the coil, therefore he put 12 volts on a coil clearly marked for an external resistor. I think that is what burned up my original coil. That is why I replaced it with an internal resistor coil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: July-01-2013 at 7:17pm
Your assumptions are perfectly valid.
You know I wanted to say .010" first but changed my mind. Chris, I don't know if my coil is resisted or not so I'm not going to change anything before measuring. Besides,. It's been wired this way since we got it in 2001. Runs fine, except the first summer when the resistor cracked and the boat died. That was the first and last time it went to a marina. We didn't have a clue back then (only slightly less clueless today) and there was no CCFan. This is how I know either the coil or the distributor or both are fed through the ballast resistor.
In Tim's diagram I think the EI jumper wire should really go to the hot side of the ballast resistor, not the coil. This way the distributor is happy getting its 12V and the stock coil is happy getting ~9V.
Johnny Mac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnny Mac Quote  Post ReplyReply Direct Link To This Post Posted: July-02-2013 at 2:40pm
Sorry to Jump in mid thread, but this seems to be dancing around an issue I have with the same setup. Let me know if it is best to start a new discussion but if all the right people are here...
My 99 Sport (351 HO) has the same prestolite dist w/ mag pickup and non-ballasted coil. The boat runs fine, but the whole circuit (incl. panel power, alternaor exciter, coil, dist) are stuck at ~9V. The battery is pushing a solid 12V everwhere else. My biggest concern is insufficient exiter wire voltage to the alternator.
I disconnected each wire in the circuit till it went from ~9V to the proper 12V. The offending part is the mag pickup in the dist. Further, I left the mag pickup wired and pulled it less than a inch up from the dist and whamo - 12V on the circuit. Then I grounded to the block and the 12V held. It seems its only when the mag pickup is in place does the voltage reduce from 12V to 9V.
Questions: Will my alternator work with only 9V exiter supply? how is the mag pick-up draining 3V when in posision, and why not when grounded elswhere.
Thanks in Advance
John MacDonald
99 Sport Nautique w/ FCT - 351HO
Seals View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seals Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2013 at 6:24pm
I've been having the exact same problem with my 79 nautique Which has a Prestolite distributor converted to EI. The problem is definitely the coil overheating. Even though ei instructions state to remove the ballast resistor, I am reinstalling it this weekend, Since the coil is likely getting too much voltage in overheating
If you carry a spare coil and reinstall it when your boat fails I would bet that everything will be fine until it that Cool overheats
Post Options Post Options   Thanks (0) Thanks(0)   Quote 93Sport Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2013 at 8:31pm
While trying to set gap for the pickup in the dizzy, I found that the dizzy had .006 side to side play in the shaft. After finding that and talking to Vince at skidim.com, I decided to replace dizzy, coil and resistor. Just ran boat for 30 minutes at 2500 rpm and I was able to hold my hand on the coil. Last time out, I got a blister from touching coil. Before I changed dizzy, timing was retarded from the shaft play. After replacing dizzy and setting timing, the boat has much better power. Out of the hole is probably 2 times faster. After a new carb and all new ignition, it runs better than it has since I have owned it.
Thanks for all the input and advice. I especially appreciate Vince at skidim.com. He tried to help me with the most cost effective solution, but when I decided to replace everything , he worked his magic to get it shipped late Wednesday so I could have it today.
must_dash View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote must_dash Quote  Post ReplyReply Direct Link To This Post Posted: August-05-2013 at 8:34am
Just put an new breakerless ignition module in mine, the instructions want a ballast resister in the line to the coil, how important is this?
Thanks
1986 Martinique - sold
When we ask for advice, we are usually looking for an accomplice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: August-05-2013 at 9:28am
It is very important. Follow the directions exactly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote must_dash Quote  Post ReplyReply Direct Link To This Post Posted: August-05-2013 at 9:38am
Thanks, will dig out the old one for the moment and order a new one
boardersdad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boardersdad Quote  Post ReplyReply Direct Link To This Post Posted: August-05-2013 at 9:51am
Check your instructions carefully--they should clarify if they are diagrammed for an externally resisted coil (ballast resistor) or for an internally resisted coil. And then confirm which type of coil you have.
Externally resisted coils can also have a loom resistance wire instead of a ballast resistor. My Mercruiser had one of those and it got old and caused all kinds of grief, so I bypassed it and added a ballast resistor. Chris, did PCM ever use a resistance wire in the harness instead of a ballast resistor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: August-05-2013 at 9:54am
Not that I have ever heard of, but I have only been in the CC game for 5 years.
Pete B. could comment on this one, as he has been around them since the 60's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote must_dash Quote  Post ReplyReply Direct Link To This Post Posted: August-05-2013 at 9:58am
There was an old resister bolted to the coil but not in use.
I have now put a new coil in. It is a Bosch Blue part number 0 221 119 027. Doesn't say on it about a resister
From Hot-spark.com
Compatible Coils
The HotSpark® HS17HEC high-energy coil (epoxy-filled) has 1.7 Ω primary resistance and 10K Ω secondary resistance.
The HotSpark® HS34HEC high-energy coil (epoxy-filled) has 3.4 Ω primary resistance and 10K Ω secondary resistance.
The following 12-volt replacement Bosch® coils should be compatible with the Hot-Spark electronic ignition module:
00 015
0 221 119 021 (Bosch Black coil)
0 221 119 020 (Bosch Black coil) (VW 022 905 115C)
0 221 119 027 (Bosch Blue coil) (VW 043 905 115C)
9 220 081 039 (Brazil)
9 220 081 054 (Brazil)
9 220 081 083 (00 012) (Bosch Blue coil)
The Bosch coils above should have a primary winding with 3.0 to 3.3 Ω resistance. Bosch coils are made in a number of countries, with varying amounts of primary and secondary resistance. It's best to check the coil's primary resistance with an Ohmmeter (a digital multi meter in the 200 Ω mode). Install a 1.4 Ω or so external ballast resistor (HS14BR) between the ignition switch (+12-Volt power source) and the coil's + terminal, if the coil's primary resistance is questionable or borderline.
Bosch 0 221 119 030 (Bosch Red Coil, Brazil) 1.6 Ω to 1.8 Ω primary resistance (OK for 6- or 8-cylinder ignition kits, not enough primary resistance for 4-cylinder ignition kits).
And from http://advanceddistributors.mybisi.com/product/bosch-blue-coil
This Bosch Blue Coil has been one of the leading coils on the market for over 20 years! Its an Epoxy filled coil, which means a very stable construction. Oil filled coils have a greater rate of expansion and contraction, allowing the windings to break over time, leaving you stranded. I've NEVER heard of a single Bosch Blue Coil failure, and in my book, that makes it worth every penny!
This coil has 3.4 Ohms of internal ballast resistance. That means its safe to use on most all 4 and 6 cylinder cars running points or electronic ignition systems (including Pertronix and the Crane XR-700.) Always check the instructions that come with your aftermarket ignition, or just call and ask!
Post Options Post Options   Thanks (0) Thanks(0)   Quote must_dash Quote  Post ReplyReply Direct Link To This Post Posted: August-07-2013 at 3:00am
The plot thickens.
Checked all the wiring and metered everything on both the old and new coils.
Ran the new coil till it stopped, it was HOT.
Then disconnected the new coil and connected in the old coil and resister, nice and cool as they had been in the tool bag. Boat ran fine till it got hot again (actually heat soaked is better) and it started messing around.
Lifted cover and both coils are hot. one electrically connected and running the engine, the other in its bracket on top of the inlet manifold and doing nothing.
Today I will move the coil to a cooler part of the engine and see if it is engine heat that's doing the heating.
Post Options Post Options   Thanks (0) Thanks(0)   Quote must_dash Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2013 at 4:44am
I have been messing around this week and the coil is getting hot electrically rather than from engine heat. The 'new' bosch gets to 77 deg C (170 F) after about 35 minutes and then starts to misbehave.
When the ignition is off the voltage to the coil is battery voltage. With engine running the alternator at idle is giving about 13.5-14v as expected, but the voltage across the coil varies between 9 and 18v.
Any ideas what causes this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2013 at 10:07am
What circuit is powering the coil? Are you sure about the 18V?   Very odd.    Maybe the alternator's regulator is bad.
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: August-16-2013 at 11:51am
Originally posted by must_dash must_dash wrote:
When the ignition is off the voltage to the coil is battery voltage. ...
Do you mean when the engine is not running, but the ignition is ON?
If you're seeing voltage at the coil with the ignition OFF, then something is wired funny.
Post Options Post Options   Thanks (0) Thanks(0)   Quote must_dash Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2013 at 6:29am
The voltage is with the ignition on and measured across the terminals of a ballasted resistor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2013 at 12:20pm
Wait, you're grounding your black meter wire to the block when you take your measurement, right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote must_dash Quote  Post ReplyReply Direct Link To This Post Posted: September-08-2013 at 11:56am
The plot thickens......
Been busy at work so limited time to play. In order to eliminate the boat electrics from the equation I hooked the coil up to a free standing battery (battery + to coil +, battery - to the block). And ran it for an hour using the bosch internal ballasted coil.
This is the coil temp when it started to miss.
So either I have:
a) knackered this 'new' coil
b) a duff coil
c) knackered the breakerless ignition module
d) a duff breakerless ignition module.
Really thinking about a performance distributors DUI for next year having lost so much time and confidence this year with this issue
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2013 at 12:05am
This thread talks about a module replacement for the setup you have:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=31242
Of course, I doubt anyone can argue with your DUI idea.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2013 at 12:33am
I don't know why there are so many coil problems lately. I was out in my MG yesterday and got stuck because the coil failed. Cheap Lucas junk, the thing lasted only 56 years . Called home and my son brought over the oil filled one that I replaced on the boat,a couple of cable ties,electrical tape and 2 W1AP cords,Jbear will know what these are and I was on my way
Post Options Post Options   Thanks (0) Thanks(0)   Quote must_dash Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2013 at 10:37am
Looks like a duff link, do you know the thread title, I get a page not available.
Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: September-10-2013 at 12:24pm
Sorry about that, I fixed it above, but I'll give it again:
Post Options Post Options   Thanks (0) Thanks(0)   Quote must_dash Quote  Post ReplyReply Direct Link To This Post Posted: September-11-2013 at 4:19pm
Thanks.
Are there any other distributors worth considering other than the performance distributors DUI?
If I'm spending the money, whats the best way to go...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 93Sport Quote  Post ReplyReply Direct Link To This Post Posted: September-11-2013 at 4:43pm
I went with the electronic version of the stock Mallory, using the stock coil and resistor. I am very pleased with the ease of installation and performance. I tend to prefer things as stock as possible.
