  New Posts New Posts RSS Feed - 1986 - 2001 overheating
sml-va View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sml-va Quote  Post ReplyReply Direct Link To This Post Topic: 1986 - 2001 overheating
    Posted: July-14-2013 at 11:49am
I just recently purchased an 86 2001. When i picked it up we ran it on the hose for about 10 min with no issues however when i put it in the lake after about 3-5 min of operation i noticed the center warning light came on and then the top light come on as well. As i began to check the gauges i saw the temp creaping up to about 200 and either steam or smoke coming out the stern so i killed the engine. What could be the cause of the overheating? I thought it could be the impeller but ran it on the hose just fine and what are the three warning lights in order of their reference. Thanks for your help
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2013 at 12:14pm
When you run it on a hose the water pressure will mask the fact if the pump is working or not. Many of us use a bucket with the boats inlet hose extended to it, that way the pump is doing the work and the garden hose is just refilling the bucket. Most likely you'll need to pull the pump and check the impeller,make sure you note how the pump mounts before you remove it it can mount either way, only one is right which might be your problem too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2013 at 12:20pm
Or you could have an air leak,either at the strainer or one of the hoses, but check to see if the pump is on right first. Here is a diagram Hollywood posted on another thread- looking at front of engine,yours should be the RH version
Post Options Post Options   Thanks (0) Thanks(0)   Quote sml-va Quote  Post ReplyReply Direct Link To This Post Posted: July-15-2013 at 6:37pm
Thanks for the feedback... it turned out that it was both the impeller and the t-stat.
