  New Posts New Posts RSS Feed - looking for x-55 parts
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Topic: looking for x-55 parts
    Posted: August-11-2013 at 5:23pm
Originally posted by AZ64-X55 AZ64-X55 wrote:
Yes Good thing we are not Judging Pete!
However that is not my boat, But if it was I would be Happy Happy! Even with the bottom paint He Painted it with. I think the boat looks great!!
EVEN BETTER THAN YOURS!! But than again I am not judging!
Thank's for your input. It's always a pleasure to hear from fellow wood (or classic) boat owner who are so well educated especially when it comes down to the ACBS judging guidelines. I however, do need to ask when you saw my X55 ether in person or pictures? I did have it at GL several years ago. FYI, my X55 has won a couple best of class's in ACBS judged shows. I'm curious about your opinion about mine. BTW, one thing I did not mention and since you seem to be such an expert, did you happen to notice the stain Mitch used does not have enough red in it? Look at the original Dunphy brochures. It may just be my monitor however, you seem to be an expert so tell me.
AZ64-X55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AZ64-X55 Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2013 at 1:36pm
just do it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-10-2013 at 5:25pm
Originally posted by MitchS MitchS wrote:
I figured out how to upload a picture. Here's a photo of my award winning X55 here in Reno Nevada- her name is "Sixty Four"
Congratulations on the award. It looks like you didn't take my advice on the bottom paint.
I will be painting the bottom of my 64 x55 in the next few weeks and was wondering what paint would be the best for finishing off the bottom?
Thanks in advance for any advice.
Where are the pictures????
They all came from factory with copper bronze bottoms so of course you do want to keep it original, correct???!!!
Since the EPA forced the removal of the tin from the old copper bronze formula, (as well as all bottom paints) the only copper bronze that looks like the original is Pettit 1959. The bad thing about the 1959 is it really doesn't have that much anti-fouling characteristics. It's fine if you are "day sailing".
That show wasn't ACBS judged so they overlooked the bottom paint being wrong. WHY didn't you go with the copper bronze????
If I was judging, I would have knocked off a couple points especially since you asked what bottom paint should be on your X55 and didn't follow through. The Pettit is an acceptable substitute with a no point deduction.
MitchS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MitchS Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2013 at 3:06am
Thx NY Nautique- I'll google that.
Mitch
Post Options Post Options   Thanks (0) Thanks(0)   Quote MitchS Quote  Post ReplyReply Direct Link To This Post Posted: August-08-2013 at 3:03am
Thanks Riley for the information. I'll try the Dexron III.
Mitch
ny_nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ny_nautique Quote  Post ReplyReply Direct Link To This Post Posted: August-07-2013 at 10:37am
Mitch, there are several old threads on the Dearbormatic that you may want to read. Do a Google search on "correctcraftfan.com dearbormatic" and you will find them.
Very nice looking!
- Jeff
1999 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: August-07-2013 at 9:26am
Nice looking Dunphe Mitch! We have 2 model C's in boats and run Dextron III in both of them. Eric Levine on this site rebuilt one of ours, but I don't believe he rebuilds trannys anymore. I had talked to the Hilpisch's and they were not interested in rebuilding them for other people. I have since met a guy in South Portland Maine that rebuilds them. We're going to have our other one rebuilt if we can ever find time to pull it from the boat. It works well, but has a dirty neutral. As long as they don't need hard parts, they can be rebuilt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MitchS Quote  Post ReplyReply Direct Link To This Post Posted: August-07-2013 at 2:11am
Post Options Post Options   Thanks (0) Thanks(0)   Quote MitchS Quote  Post ReplyReply Direct Link To This Post Posted: August-07-2013 at 1:53am
Art,
do you have any knowledge of the Dearbomatic model "C" transmission? I'm having issues getrting a good read on the right fluid to put in it. the interceptor manual says put type "A" hydraulic transmission fluid in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MitchS Quote  Post ReplyReply Direct Link To This Post Posted: August-07-2013 at 1:47am
I am afraid I do have the Dearbomatic. It worked great with the trans oil that came with it, until I changed the fluid and put ATF in it. With ATF it ran fine on the lake for awhile, then after it got warm it started slipping. If I turned it off for awhile on the lake, it would go again, but slowly.
It is the "C" model in the yellow interceptor manual and has its own oil pump internal. I got hold of the Hilpisch father and son and they mentioned it should have 30 weight in it or 15W40. When I put 15W40 in there it immediately turns even while in neutral. Once it warms up it begins to act more normally and while running on trailer I can get it to stop in neutral and do both forward and reverse- but not consistently.
Steve Sr. mentioned I should have at least 100 psi to get forward and reverse and I checked it and I have 120 psi, so that's not a problem.
Interesting thing about the tranny is when it does engage it makes a bit of a whining / low growling sound- that's how I can tell it is engaging and turning normally.
I would like to keep my Dearbomatic and wonder if I can pull it and work on it myself- I am pretty good mechanically if I can get some insight on what I need to fix.
I would post a picture of it, but can't figure out how to do that just yet- BTW, the Dunphy X55 it sits in just won 2nd place in Class at the South Lake Tahoe Classic show end of July- I'd like to post a picture of that, too if I can figure that out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: February-17-2013 at 2:08am
He's on a fixed income now Bruce and dipping into the parts retirement fund
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-16-2013 at 8:15pm
Originally posted by ArtCozier ArtCozier wrote:
The C is the one that is not integral with the bellhousing, right?
Correct. It has it's own pump built in.
ArtCozier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ArtCozier Quote  Post ReplyReply Direct Link To This Post Posted: February-16-2013 at 8:09pm
I think I remember that now. I'll pull it out of storage and try to spin it on the bench and see whether it works. That's how I test all the units that I rebuild. The C is the one that is not integral with the bellhousing, right?
"Art"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: February-16-2013 at 8:01pm
I was almost begging you to part with one a few years ago and I couldn't talk you into it. Do you have a good working model C? I'd be interested in buying it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ArtCozier Quote  Post ReplyReply Direct Link To This Post Posted: February-16-2013 at 7:58pm
Did someone say "I like Dearbos"? I have a couple of them and I'd rather have dollars than these trans.
Art C.
"Art"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: February-16-2013 at 7:38pm
I've grown to like the Dearbos. No doubt they won't last forever as hard parts are very difficult to find, but if you have one that works well, I don't see the need to be in a hurry to get rid of it. The Hilpshe's love them and according to Steve, if people had only changed their fluid once in a while, there'd be a lot more of them still around.
boat dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Posted: February-16-2013 at 5:20pm
Stay tuned for the rest of the story Bruce.You will have a failure with that C model, the smaller cubes were not as bad, but they all failed....They were built from a few custom parts and a lot of Ford-o-Matic parts, use what you have in stock...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: February-16-2013 at 4:11pm
What's the matter with the Dearbo? The Dearbo C's work great, weigh half as much as a Velvet Drive and were made by Interceptor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-16-2013 at 3:49pm
Mitch,
Sorry I missed this post but we have been emailing each other. I sent you an email this morning about the repairs you are making.
BTW, the engine is a 312 and not the 292. Hopefully you do not have the Dearbomatic trans and your X came through with the Velvet Drive. The switch was about mid 64.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MitchS Quote  Post ReplyReply Direct Link To This Post Posted: February-13-2013 at 11:21pm
Hey I noticed this post from the past.
Not sure if you are still into Dunphy X-55s, but I just got a 1964 Dunphy X-55 from California. I has been a California boat since the 60s as far as I know- around the bay area (Novato area). I now have it in Reno, Nevada and plan to run it this summer on Lake Tahoe. It has the 292 interceptor and most of the hardware looks original. I do think the vents need re-chroming or replacing- missing the bottom piece on one of them. On the sides, the mahogoany ply laminate on the plywood has mostly come off- so I scraped the rest off and am refinishing it with mahogany ply (7mm)and will stain and spar varnish it in a natural finish (both sides and stern), then original vinyl top sides, seats and interior panels . If you have any ideas or pictures I would greatly approciate it- especially of the rear seat since it was totally missing when I got it. It has the green line Stewart Warner gauges, but I am looking for a speedometer that matches the rest of the gauges.
I would like to restore it as original as possible. The engine runs great- I just cleaned up the y side carbs and got it running pretty well. I got a rebuild kit for these and hope it will be a solid runner for sure then. The trailer looks original to the boat- made by Cal Trailers and has much surface rust but i'll sand and paint and should be fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2010 at 9:03pm
Russ???
Did you get the pictures or not?? I di d get your email but if you can't open them and respond, I can't help!! Sorry.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2010 at 2:54pm
Russ,
I found you email address! Doubly now!! I just sent you the two zip files again.
How about emailing me some more pictures?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2010 at 2:04pm
Russ,
The reason I need you to email me here at home is because I didn't save your address!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2010 at 1:59pm
Russ,
It's not supposed to have fiberglass on the bottom!!!! It's truly "the kiss of death" for a wood boat. Someone at one time did a "half ass" on the bottom. Yes, it won't stick and all will eventually come off. It also holds water so the bottom will rot FAST!! With the hull to frame fastening failing, it flexes at joints. A layer of glass won't hold it together. Since you're flipping the hull, I suggest new ply. Removing it may also uncover some hidden surprises with the frame. My inner keel was mush under the engine. White Oak for any frame repair.
Email my home address and I'll try to send you the zipped files again. If you still can't open them, I'll start sending the pictures individually.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AZ64-X55 Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2010 at 1:46pm
Pete, no I have not been able to open any pics you sent me!
I have a velvet drive in mine. and it is red? the for sale add said it was rebuilt. not sure why it is red, I thought it was the wrong drive but not sure??
I have replaced the sheer on the boat the last too weekends, just about time to turn it over and go over the bottom, all looks good from inside but there is some fiberglass that is not bonded to the plywood!
In the box of parts there was the logos( 1 broke) the hole in ones, the front light, rear light base (need the light pole!)and the step plates with the dunphy steplogo.(they might make good forms to make new ones.
just do it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2010 at 10:49am
I've got one of the "odd" ones that doesn't seem to indicate a year!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2010 at 7:10am
Originally posted by h2oproofer h2oproofer wrote:
I am told the actual serial number is a 63- # but I am told there is no such thing as a 63?
Seth
Seth,
Whoever told you this is not the person to be talking to concerning a X55!!! I suggest you stay away from him if you want a correct and true restoration.
A 63 should have a solid color vinyl deck rather that the split two tone. Unless someone did a trans swap, you should have the Dearbomatic trans if it is a 63. Does your engine/trans run? Condition of the hull?
Craig (64X55) compounded some serial/hull numbers at one time and found some numbering inconsistencies but most likely the 63 in yours is indicating the year.
You can also check the year of the engine. The numbers on the front next to the mechanical tach output. I have the numbering code if you need any help.
The X was built in 1963, 64 and 65 when Dunphy again went bankrupt. The bankruptcy is felt to be from them warranting there bottoms. The first batch of Philippine Mahogany they were using was bad. The wood used to make the ply had a fungus in it that caused the veneers to delaminate. They took lots of the boats back and put new bottoms on them. Mine didn't go back to the factory but I did end up having to put a new bottom on it back in the early 80's.
Russ,
Glad to hear you found some of the parts! What trans is in yours? It was sometime in late 64 when the X's started coming through with Velvet drives direct from the factory. The Dearbo's were having a hard time with the 312's. Fine on the smaller engines though. Mine has the Velvet.
Were you ever able to open that file of pictures I sent to you? If not, I could start sending them individually!! Also, Did I send you one or two files? I think it was just the file on the dog house. I've got another one with even more pictures.
Email me direct to home at hideed41@att.net
Post Options Post Options   Thanks (0) Thanks(0)   Quote AZ64-X55 Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2010 at 2:05am
I also have 1 good one that came in the box of missing parts.
Craig is in need of them also. What point of restoring are you at?
just do it!
h2oproofer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote h2oproofer Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2010 at 11:44pm
I to am restoring a 64' X 55? so I am told the actual serial number is a 63- # but I am told there is no such thing as a 63? It is also missing the dunphy logos from the sides. I have all the other chrome. However, I am working on having some cast and then plated. I have one I can use for the casting. Part of the cost is the molds etc. Maybe we could get together and help lower the cost.
Seth
Post Options Post Options   Thanks (0) Thanks(0)   Quote AZ64-X55 Quote  Post ReplyReply Direct Link To This Post Posted: July-08-2010 at 9:07pm
I just got a call from the previous owner. HE FOUND A BOX OF DUNPHY PARTS!!! THE LIST JUST GOT SMALLER!!
just do it!
