  New Posts New Posts RSS Feed - Stern Lamp Lens
Stern Lamp Lens
Rick in MA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick in MA Quote  Post ReplyReply Direct Link To This Post Topic: Stern Lamp Lens
    Posted: August-15-2013 at 1:36am
Oh where Oh where can I find a replacement lens for my '80 Stern lamp?
White plastic, Pharo's hat shape. No clue as to the manufacturer but it is the original.
JPASS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPASS Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2013 at 11:09am
Try Christine's
Stern Light
'92 Correctcraft Ski Nautique
ArtCozier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ArtCozier Quote  Post ReplyReply Direct Link To This Post Posted: August-15-2013 at 3:46pm
I never saw a Pharo wearing his hat. Any better description?
I have a whole mess of old stern light lenses, all identical. They look like a shot glass, 1-7/8" in diameter at the open end, about 1-1/4" at the closed end. It has a slightly rounded top. (or bottom, if you are using it as a shot glass!) Height is 2". It has a coarse thread inside the open end. They are made of translucent plastic.
I don't recall what years we used these, but perhaps you'll be lucky and this will fit.
Art
"Art"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick in MA Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2013 at 1:18pm
Thanks for the inputs. I have ordered an Atwood that seemed to meet the dimensions. Art, If I don't succeed here could I send you the broken one to attempt to match it up. What a hokey set up this whole stern lamp is.... knurled brass contacts pressed into nylon.... Thanks again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2013 at 3:06pm
Rick,
CC did go low end on some of their purchased components through the years. I'm glad to hear that you found the lens.
Regarding the knurled brass contacts in the Nylon, how would you design it? Are you sure it's Nylon - how do you know and what's the matter with it? The contacts do need to be electrically insulated so a plastic of some sort is a good choice. Are you having problems with the staff and base making a good electrical connection?
BTW, I have never had a problem with mine. Are you running in a salty area?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick in MA Quote  Post ReplyReply Direct Link To This Post Posted: August-20-2013 at 12:25am
Perhaps I should be more forgiving of the design..After all it lasted for 33 years!! The underlying issue was that unless the lamp was dropped straight onto the pins it would push one or both of the pins out of the socket. Corrosion was not an issue. My fix was to make new contact pins with a shoulder on the socket side that would not allow them to be pushed thru. Threaded on the backside with nuts to secure the pins in the socket. The heights of the contacts on the outside were staggered to isolate the electrical connections. I wish I had taken photos but I think what I have is "wifeproof". Now I need to replace the lens that I broke in the process of the other repair. I love this old boat!!.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick in MA Quote  Post ReplyReply Direct Link To This Post Posted: August-24-2013 at 11:01pm
The Atwood lens was the correct replacement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-25-2013 at 10:43am
Rick,
Glad you engineered a correction. The "wifeproof" comment was great! In my case, I have to also include son and daughter proofing!
