Stalling and other problems |
83Southwind ![]() Newbie ![]() Joined: September-10-2004 Location: United States Status: Offline Points: 22 |
![]() ![]() ![]() ![]() ![]() Posted: September-10-2004 at 9:20am |
My 351 PCM has developed a stalling problem. When shifting to forward from an idle or to pull a skier. I plan to change the plugs. How do I change the fuel filter. Is there a maintenance manual?
Also a water petro mix has appeared in the bilge after a day on the lake. Suggestions for finding the source. I also want to install a winch on the correct craft trailer for retreival and steep ramps. Where can I find on that will compliment and 83 model trailer? |
Wick
IrishFooter ![]() Groupie ![]() Joined: October-02-2004 Location: United States Status: Offline Points: 64 |
Check the timing. Check the spark, check the points, check the fuel/water seperator. Remove the fuel line coming into the carb and see what pressure you have when cranking the engine. Visually inspect fuel lines to see if you can see a fuel leak. Decreased fuel delivery could casue such a problem as well
1979 Ski Nautique
