  New Posts New Posts RSS Feed - Steering Problem?
Steering Problem?
BeeJay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BeeJay Quote  Post ReplyReply Direct Link To This Post Topic: Steering Problem?
    Posted: September-24-2013 at 3:37am
Last time out for the season and had nothing but trouble this year. Finally boat was running like a top, then after an hour runtime another problem reared its ugly head. The steering became excessively stiff, especially to the right.The hell with it, I was going to get my last run in no matter what.Wife pulled me for about 3 miles but when she picked me up after drop off, she said it took all her strength to turn the boat around.Took over operating and she wasn't kidding, that wheel was stiff at cruising speed and beyond. But at lower speeds was tolerable although not great.Back home and on trailer steering was quite easy but maybe a tad stiff for open air operation. Removed tiller arm and no change in freedom of movement. Manually checked rudder and its very smooth to turn. Now heres my dilemma-in open air the steering stiffness isn't bad and by the same token its not quite good either-what to do?
A little history:
    Boat is a '97 Nki Nautique purchased new
    Has 300 hours of TLC running time
    Never had any noticeable steering problems (Rack Steering)
    Slop in the wheel is about 1 hour as viewed in 12 hour               clock face.(30 degrees?)
    Boat unknowingly had filled with water above cockpit sole during storage (about 3 weeks).
    2nd time out cooling water hose came off and flooded bilge with hot water before noticed.
Now I am wondering why does the wheel turn freely in open air and very stiff in the water (I am aware of prop thrust fighting back at me, but this takes MUCH more effort than it used to!Is it possible that something in the system is binding when under load? I'm kind of at a loss here and not looking to spend $350 for a new cable/rack assembly if not needed.SOS
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: September-26-2013 at 1:55pm
The cost of the cable is more like $200 or so.
Take a close look at your helm side for two reasons:
1.) There is two possible cables (has to do with the shape of end of the rack). http://www.nautiqueparts.com/steeringcableallnautiquesfrom1993to1997.aspx
2.) You want to make sure the teeth in the gears that move the rack aren't damaged. It's not likely, but if you've been running with an extremely bad cable for a while, it's possible. You'll have to unbolt the rack to do this.
Check out my write up on doing it yourself:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=31166
Post Options Post Options   Thanks (0) Thanks(0)   Quote BeeJay Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2013 at 2:20am
Bri
Great post on cable replacement.This will help a lot when the time comes.Have a few questions for you-
   Did you remove drivers seat for access to the helm end?
   From what I gathered, the 20 ft. cable required that a new style helm was needed also, did you replace that?
   Looks like my '97 may need drivers seat and two panels removed in that area to gain better access. Probably no big deal to remove. I have the older style cable (smaller cross section). The 19.5' OEM cable is $299. The newer 19.5' cable is $185 and requires a new helm along with it @ $75 for a total of $260. Cheaper, but I don't know if I will have trouble with tilt steering removal. I guess my helm pinion gear condition will determine which way I go.
At this point I am still not sure exactly where the problem lies, but my thinking is that if the steering is somewhat stiff in free air, the resistance or binding must get multiplied under load. As much as I hate to shell out the cash for these parts, its probably the only way out.
Thanks again for the tips!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: September-27-2013 at 11:38am
Thanks.
I left my drivers seat in place, but probably would make the steering cable replacement easier if you removed it.
Well, there's really 3 cables options, although that's not super clear. There is the newer style, which requires the new helm. Then, there's two options for the older style (square-er looking down the end). The original length is the more expensive. But, it's about $100 cheaper to get the slightly longer one, because they're more common. I guess they're still the same manufacturer.
I went with the longer old style end, and kept my original helm. I think the extra length is like 6", and I couldn't tell. There really wasn't any extra cable to deal with.
Make sure you grease the zerk fitting on your rudder port, if so equipped. But still, sounds like a text book cable issue to me.
GlassSeeker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: September-29-2013 at 11:09pm
Classic case of worn out cable including denial. Replace and rejoice
This is the life
Post Options Post Options   Thanks (0) Thanks(0)   Quote BeeJay Quote  Post ReplyReply Direct Link To This Post Posted: September-30-2013 at 2:19am
Yes-ordering cable tomorrow morning. Unbolted helm, pinion looks good. Disconnected rudder end, rudder turns freely. Only thing left was cable,cannot budge it by hand and helm end looks dry as a bone as to grease. Will purchase same cable as Bri bought.Was advised by customer service to repack rudder shaft while I had everything stripped down. Ordered packing and safety wire also. Don't know what type of grease to use so I guess I will go with my waterproof trailer wheel bearing grease. Kind of anxious to replace all parts and see how it works out.
