propeller |
PNALEWAJK
Newbie Joined: May-01-2009 Location: United States Status: Offline Points: 34 |
Posted: October-14-2013 at 12:37pm |
I need to have my prop worked on (hit a stone). Any suggestions on how to remove it from the shaft? I don't have a puller.
Corvette Pete
IAughtNaut
1- get a puller
2- you got a marina or a repair shop near you? They probably have one and will let you use it for a few bucks. you could try getting a block of wood behind it and tapping it with a hammer (repeat- TAP), but you're asking for problems if you miss. Either way, after you loosen the nut, leave it on the end of the shaft, that will keep the prop from hitting the sidewalk when you get it loose. They don't bounce well. |
phatsat67
A puller is a great investment.
PNALEWAJK
Thanks. I'll see I can borrow a puller. Can someone explain to me about "lapping" and if I need to do this if I'm putting the same prop back on?
Corvette Pete
CrazyCanuck
Senior Member Joined: July-21-2013 Location: Vancouver B.C. Status: Offline Points: 254 |
https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcRtW3vJrMHLdqBzndt9VX3oOpBuRopGlzKq9Ea7pAO7wnTuoD8E8g
boardersdad
Senior Member Joined: June-18-2013 Location: Wisconsin Status: Offline Points: 409 |
Lapping is easy. You should do it.
Steve |
PNALEWAJK
That looks easy enough, but is it necessary if putting the same prop on the same shaft?
Corvette Pete
Bones71
Senior Member Joined: March-09-2013 Location: Bettendorf Ia Status: Offline Points: 334 |
Peter, it really doesn't take long to do. It's easy. If it's never been done on your boat it's good peace of mind knowing you did it right. If you bought the boat and never changed props how do you know if it was properly seated right on the shaft in the first place? It's one of the easier things I've done in my adventures this year. Tony.
That money talks, I'll not deny, I heard it once: It said 'Goodbye'
Plus a good prop shop sometimes run a reamer down the prop changing what you had.
PNALEWAJK
Okay. Thanks guys!
Corvette Pete
Exactly! The reamer used may not match the shaft taper! Lap it on. Yes, get a prop puller. |
