  New Posts New Posts RSS Feed - Performamce Bumpstick questions
29EHV8 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 29EHV8 Quote  Post ReplyReply Direct Link To This Post Topic: Performamce Bumpstick questions
    Posted: October-28-2013 at 5:29pm
Eh guys, sonwhat have you guys run for a performance camshaft? And any pros n cons? Would like to hear from guys who have run em, not stories and myths hehe
Not looking for anything to krazy... well maybe!
Thanks
-Shiny
Low buck, Cool as F*ck
Hot Rods
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-28-2013 at 5:36pm
The biggest roadblock youre going to have is the fact that the original engine in the ~80 Ski Nautique youre working on was originally reverse rotation... and should probably remain so in order to preserve the proper handling and balance of the boat.
Reverse rotation roller cams do not exist unless you get one custom made. Budget $1500-2000 for this upgrade.
The flat tappet reverse rotation blanks available for small block Ford windsors these days are somewhat limited in the amount of lift/duration that can be put into them. The amount of the heat treat dictates that they can only be so wild. The one commonly recommended is the .460/.460 (with 1.6 rockers) that Cam Research sells. With 1.7 rockers, you get reasonably close to .500, which should work well for the common GT40p head upgrade if youre content with the ~325hp level.
If you want to go bigger than that, roller is the ticket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 29EHV8 Quote  Post ReplyReply Direct Link To This Post Posted: October-29-2013 at 3:56pm
Woah, $2000 just for the roller cam, ouch!
325HP should be ok, don't want a gas pig either
Been looking into GT40p heads, gotta hit up some of my Ford buds
I will call Cam Research, cuz you can't see much on their site really
Thanks for the info.
Anyone else have different experience?
-Shiny
Hot Rods
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-29-2013 at 4:13pm
Yes, call Cam Research- theyre a small shop with a next-to-worthless website. 325hp in that hull makes for a very fun ride. More hp does not mean the boat will use more gas.
