Engine Hatch |
Fred
Newbie Joined: February-07-2014 Location: Arizona Status: Offline Points: 5 |
Posted: February-07-2014 at 1:33pm |
Looking for Engine Hatch for 03 Super Air 210
phatsat67
Fred, I can probably have Correct Craft produce one but it will more than likely be quite a bit of $$$$. Let me know if you'd like an estimate.
Air206
Fred:
Do you mean the electro-hydraulic actuator lift mechanism or the fiberglass sunpad which is upholstered? The actuator has replacements (as they failed often early on) but they ain't cheap! |
Fred
That would be great, but I don't know if they have mold
Air206
Fred
Fiberglass Hatch
Air206
I might check with an RV repair shop. Travel trailers and truck camper walls are mostly gel coated fiberglass over ply or synthetic ply. Repair shops may have remnant white panels that you could use as a base and then build up and re-upholster. Just throwin' it out there....
phatsat67
No dice, The mold is long gone. Can still get the skins though.
