  New Posts New Posts RSS Feed - Engine Hatch
Engine Hatch
Fred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred Quote  Post ReplyReply Direct Link To This Post Topic: Engine Hatch
    Posted: February-07-2014 at 1:33pm
Looking for Engine Hatch for 03 Super Air 210
phatsat67 View Drop Down
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2014 at 2:36pm
Fred, I can probably have Correct Craft produce one but it will more than likely be quite a bit of $$$$. Let me know if you'd like an estimate.
Air206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2014 at 2:43pm
Fred:
Do you mean the electro-hydraulic actuator lift mechanism or the fiberglass sunpad which is upholstered?
The actuator has replacements (as they failed often early on) but they ain't cheap!
Fred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2014 at 2:44pm
That would be great, but I don't know if they have mold
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2014 at 2:44pm
Fred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2014 at 2:47pm
Fiberglass Hatch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2014 at 3:07pm
I might check with an RV repair shop. Travel trailers and truck camper walls are mostly gel coated fiberglass over ply or synthetic ply. Repair shops may have remnant white panels that you could use as a base and then build up and re-upholster. Just throwin' it out there....
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2014 at 4:41pm
No dice, The mold is long gone. Can still get the skins though.
