  New Posts New Posts RSS Feed - k&n flame arrestor
k&n flame arrestor
lakedog55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lakedog55 Quote  Post ReplyReply Direct Link To This Post Topic: k&n flame arrestor
    Posted: March-14-2014 at 11:31pm
Is anyone running one. Trying to figure out which way to go. Where does the fuel overflow hose go?
Not sure which one. Standard throat but worried about clearance after new intake
Mike
Lakedog55
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-15-2014 at 8:41am
Looks nice, very expensive, but most importantly, too tall. You won't find one under 3.5"... If you do, you're looking at "element height" not overall height. Definitely won't clear a 2001 box unless you've got a stock intake. A performer barely fits with a short arrestor. Pass!
Post Options Post Options   Thanks (0) Thanks(0)   Quote lakedog55 Quote  Post ReplyReply Direct Link To This Post Posted: March-15-2014 at 11:12am
10-4 . Been searching for one that is short. You guys got any suggestions on what I should do.
thought about cutting mine down.
mike
Lakedog55
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-15-2014 at 11:21am
If you can get yours apart, cutting it down is a good option. 2" is the lowest you can go without getting hung up on the j-tubes. Otherwise there are a few options out there, but it's tough to find one with all the fittings you need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lakedog55 Quote  Post ReplyReply Direct Link To This Post Posted: March-15-2014 at 12:41pm
Do I have to have the breather tube for oil fill? I know I need the fuel pump over flow. Actually my first river run fuel pump went bad. So I know that is a must. Two inches that sounds good, no money and some straight aviator snips(yellow).
Lakedog55
Yeah i am having trouble finding one.
Lakedog55
Waterdog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: March-15-2014 at 12:47pm
The Steath intake I used is 2in taller than stock. I cut down an arrester and built a 15in one using a Moroso low profile air cleaner. There's pictures posted here from about 3 years ago - I've looked for an hour for them.
I bet TRBenj could find & post them in 30 sec. (hint, hint)
- waterdog -
78 Ski Tique
jblocal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jblocal Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2014 at 7:44pm
I was considering buying this arrestor. I was getting some dirt in my carb with that stock arrestor and thought this style would catch more dirt. I have a Fishnautique so height is no issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2014 at 8:34pm
getting dirt in your carb,you offroading that boat? I have heard somewhere don't know if it was here or the Shamrock site that some of the K&N's do not have the Coast Guard approval stamped on them,my guess is thay use a sticker and it falls off because they are CG approved. My point is you living in Stewart have to be careful,the CG does check. Not marked,it's your word vs their's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2014 at 8:57pm
Bling and let the USCG give you problems???
bhectus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bhectus Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2014 at 10:20pm
K&N sure spends a lot on advertising! Real world tests prove there are better filters out there for the money. They may work ok on carb'd engines but on newer FI engines they flow oil into the MAF and start causing sensor issues.
'87 Barefoot - sold
'97 Super Sport Nautique - originally custom built for Walt Meloon
'97 Ski Nautique
'83 SN 2001
Post Options Post Options   Thanks (0) Thanks(0)   Quote jblocal Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2014 at 11:10pm
Lol ya I must of been
