piston install |
bwooton
Groupie Joined: June-13-2005 Location: United States Status: Offline Points: 91 |
Posted: October-23-2006 at 5:31pm |
Hey guys i need a little help. i am building a 350 for my 79 tique and when i instll the pistons something just does not seem rite. It is harder than it should be to rotate the crank. "i know how hard it should be"
i have found the source of the problem to be the oil scraper rings. If i take them off and put the piston in with just the other rings it is fine. I know the scraper rings should add some resistance but not as much as they are. |
Thanks Bobby
there's no replacement for displacement |
do you have the piston 180 off ? are you building a rev rotation engine?
64 Skier
Senior Member Joined: February-08-2004 Location: United States Status: Offline Points: 415 |
What is your piston to cylinder wall clearance?
05 210
Platinum Member Joined: February-17-2006 Location: Southern Maine Status: Offline Points: 1481 |
Check the end gap of the oil rings in the cylinder,maybe they are the wrong ones.
Mike |
bwooton
All the gaps are correct. I made special effort to check each one.
the pistons are going back in just as they were removed. Same bore same direction. I will have to double check that piston to cylinder spec, but i am sure that it was within tollerance. I think my compressor may have something to do with it. It is the cheap type with two bands that you just tighten down. it does not seem to sit correctly over the bore. i am going to buy a different compressor and see if that does it. |
Thanks Bobby
bwooton, got a hydraulic roller cam with 50 hours on it, will sell very cheap eric, came from a 280 5.7 eric
just thought you might be interested i have the lifters and the broomstick |
