Commander 351 |
captbob626
Senior Member Joined: September-12-2013 Location: Cape MAy,NJ Status: Offline Points: 203 |
Posted: April-15-2014 at 7:50pm |
Does anyone have a front end picture of a commander motor? I am tiring to figure how the hose is routed from the thermostat housing to the circulating pump. On a commander the alternator is on the starboard side and Po had a hose going around the alternator. I was told a molded hose goes between the alternator and the motor and not around the alternator.
Thank you |
Bob Meimbresse
hotboat
Gold Member Joined: March-28-2009 Location: Conn Lake Pa Status: Offline Points: 814 |
Out around the alternator was correct on my 78, not sure if it was ever different
Brian
No molded hose there on any Correct Craft I've seen.
It would be awfully stupid to design the outlet going one way and for the hose to go another. Hope you didn't pay much for that advise. |
captbob626
Thanks guys,what hose did you use to make that bend? It rides 2" shields and looks like it may kink. It has wire inside.
Bob Meimbresse
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21171 |
Now you can say youve seen one. Not sure if its original, of course... but Conquerer-Crusader routed that house around the alt like Commander did anyways. A good strong wire reinforced hose should make that bend. |
captbob626
Hey, thanks Tim. That looks like the hose that was on the engine. I bought a hose (shields ) frome a marina round here. But doesn't make that clean bend. I'm afraid it may kink. Maybe I can find another mfgthank you
Bob Meimbresse
rapok4
Senior Member Joined: August-09-2013 Location: Jacksonville, F Status: Offline Points: 118 |
Tim, that sure is a nice engine but not the one in question.
Duh. It's a correct craft with a molded hose in that location. Lower picture is a commander, showing how they routed the hose. |
I guess I need to be more specific for some users here. I was referring to ONLY the engine in question...
captbob626
Thanks guys, I picked up a new piece of hose. Looks like the spring is tighter wound and makes the bend without kinking.
Bob Meimbresse
