  New Posts New Posts RSS Feed - PCM 351 exhaust manifolds
KTempleton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KTempleton Quote  Post ReplyReply Direct Link To This Post Topic: PCM 351 exhaust manifolds
    Posted: March-28-2014 at 2:33am
Was prepping mine for paint after replacing gaskets and found some surface cracks in them. Not really something I would ever consider used. But this boat hasn't seen the water in a while and trying to avoid putting a lot of money in it until I know the motor is strong. Plan on getting new ones once I know it's not going top blow once it's under load
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2014 at 12:02am
Kyle,
Pressure test the ones you have.
Dreaming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2014 at 1:32am
Kyle, I was in the same boat last year with my manifolds... Alpha don had some for sale, but by the time we connected via pm, I had found another set.   I'll pm you his email address.
Good luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote KTempleton Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2014 at 7:21pm
Yeah They were just surface cracks that I did some grinding and filling on. but after all that work I put back on and went to screw in the new drain caps and the threads are completely gone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2014 at 7:25pm
Did you try to chase the threads?
matt05sv211 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote matt05sv211 Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2014 at 8:53pm
Let me know if you are still looking for a pair of manifolds. I have a lot of extra parts from an engine swap I just did in my 2005 sv211. Excalibur 330 motor by PCM.
repip_piper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote repip_piper Quote  Post ReplyReply Direct Link To This Post Posted: June-20-2014 at 12:21pm
Hi All,
I am looking for the driver's side exhaust manifold for my 89' SN with a 351W. I have what looks like what could be a crack. How do you seal it up to do a pressure test?
Thanks,
Vern
ArtCozier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ArtCozier Quote  Post ReplyReply Direct Link To This Post Posted: June-20-2014 at 12:40pm
There isn't a good way to pressure test them without taking them apart and making a blank plate to block off the water passages, and then that doesn't test the risers.
One way that will tell you if you have a big internal leak is, with the risers on, to put a 3/4" pipe thread X garden hose thread in the water inlet and turn the hose on full=blast. Have the manifold assembly upright. (in running position)   If water comes out of any of the exhaust dumps, you've got an internal leak. Water will come rushing out of the exhaust outlet, but that's OK. Let it run for a couple of minutes, at least. Note that this is best done with the manifolds OFF the engine.
I have a pair of used Osco replicas of PCM manifolds, but I don't have any 3" risers.
"Art"
