GT-40 Fuel Pump Replacement |
Breck-Nautique
Newbie Joined: January-10-2009 Location: CO Status: Offline Points: 3 |
Posted: June-30-2014 at 5:39pm |
Hi All,
The high pressure fuel pump replacement for the 1995 GT-40 EFI fuel system (without the FCC) at Nautique Parts has an output line connection that is different than the OME connection and is stated as such on the Nautique Parts web page. I’m wondering if anyone has replaced their original pump with this pump and what they used to make the output connection to the fuel rail connection. Thanks in advance for your input. |
Breck-Nautique
Thanks gun-driver.
Now that I look at your post and then looking at my setup a little closer I think you are correct. I was thinking the new pump had a taller line section between the pump to the connection nut. But after looking again at your post and my pump this section of line is covered by the rubber mounting bushing. My bad. Sorry for the confusion. |
