  New Posts New Posts RSS Feed - Slow speedometers
Slow speedometers
KRoundy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Topic: Slow speedometers
    Posted: August-10-2014 at 12:15am
On my restoration project boat I'm moving on to the little things now. I have two NOS Airguide speedos that I got from Mr. Mabe some time ago (THANK YOU, Marty!). Out on the water they are:
A) very slow to respond.
B) erratic in functionality (sometimes they don't work at all).
C) give different readings at different times (sometimes the one on the left is showing a higher speed, at other times the one on the right)
What's the most likely culprit here? Before you answer I'll provide more data:
The pitot pickups, brass tubes (whatever those things are called), and the tubing all have 1000's of hours on them. I've cleaned out the plastic pitot pickups from the bottom. I might try running a wire or something down from the top, but I think they are clear.
My theory is that "stuff" is somewhere. Either in the brass tubes, or in the air lines running to the speedometers. If it is the tubes, I could remove and either replace or clean them out (or remove them altogether). If it is the lines I can purchase replacement tubing from N3 or other site sponsors.
Or, could I be missing something else? Help me, friends. I don't want to randomly replace parts hoping the problem goes away.
Kevin
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-10-2014 at 8:40am
Kevin,
You need to check for leaks or plugs in the pitot tubing and the brass cushions. It wouldn't be a bad idea to replace the tubing.
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: August-10-2014 at 8:48am
I have the same problems every now and then. Take a good look at the hose where it sits at the pitot. Dry rot cracks sometimes form there aggravated by sun exposure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: August-10-2014 at 10:15am
I think replacing the tubing and making sure the brass tubes are clear is the right thing to do. Good question on the tubing that is outside the hull, Orlando76. On both sides the tubes are quite discolored and stiff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-10-2014 at 10:19am
Kevin,
Take a good look at the brass pulsation dampeners. If the have ever been plugged, they will hold water that will freeze and split them open. A solder job on the split is the answer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: August-10-2014 at 12:26pm
Thats the only thing I like about the "replacement" teleflex pitots. Theres a compression fitting that gives a wee bit more protection for that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2014 at 1:00am
Kevin,
Good thought. I wonder if I can get back there without removing the fuel tank. If not I can investigate my fuel level sender resistance levels at the same time and kill two birds with one fuel tank removal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2014 at 10:03am
Nope, ain't happening!
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2014 at 11:27am
Nothing but problems these old speedometer systems are.
GlassSeeker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2014 at 3:09pm
I'm really impressed by the accuracy of airguides. Since they are reacting very close to realtime I use them onmy way up to speed and then use my GPS to dial in the speed. Sure debris knocks em out sometimes...then refer to tach.
This is the life
