TSC1 Nautique Top Speed? |
Post Reply | Page <123> |
It's the angle(rake) of the blade to the hub
Toertel
Gold Member Joined: August-26-2013 Location: Atlanta Status: Offline Points: 775 |
I should not post in the middle of the night after some drinks... What I wanted to say is, that the temp is always the same once warm ( shy of 160) even after longer runs at 4000 ish. But when running at top end it creeps up a bit (+10) and once back to lower rps drops in seconds to what I see all day |
1994 Sport Nautique
backfoot100
That's normal. Run it like you stole it. |
Eddie |
Nautique2001
I assume the engine is working a lot harder with a more aggressive angle. The bow of my boat does seem to ride low to the water at higher speeds.
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Online Points: 21186 |
Nope, that's not the way to think about it either, Ken. The tsc hull is a slow one- it plants the nose by design in order to make the slalom wake small. A prop like that oj you have exacerbates that slightly since it has less aft rake than something like an acme 422. That will lift the stern slightly, which pushes the bow down.
Toertel, I'm not convinced that elevated temps at high speed are normal, my PCM fords certainly don't behave that way. Your RWP may be marginal. |
Toertel
The rwp is less than a year old, new impeller and hose tight.
We run it on lake lanier which is right now around 86. And I can only see it after we run pedal to the metal/run it hard (temp then is little over 160), once rpms below 4200 will drop it again immediately On the engine it says WOT rpm continuous should be 4200 and max/peak 4800. Speed at 4200 is 40ish with the FAE. Ya'll rev it much higher? Should I just disregard the engine plate ? |
1994 Sport Nautique
5200 here, 80 degree water and it doesn't creep up.
Toertel
I'll check hoses etc again and keep an eye on it. Anyway doesn't your engine have a plate on it that says the same re rpm as mine on the black plastic cover next to the GT-40 sign? I haven't even tried to run above 4800 so no input from my end re top speed once over these rpms |
1994 Sport Nautique
No plate but I'd ignore it if it did... I tear off the tag on my mattress too.
Tim is misleading you a bit. He doesn't have a GT40, let alone an EFI Ford...
Also, some of you GT40 owners could be running 160 thermostats. However, if your engine normally holds 160 you probably have the 143 thermostat. |
Toertel
Thx Hollywood. But I did listen to him anyway and ordered a 422 prop, hoping that Nautiquehunter can borrow me a prop puller |
1994 Sport Nautique
Irrelevant for the purposes of this conversation, as the bottom end and cooling system are the same, and the top end is close enough to make an apples to apples comparison. At least in terms of cooling ability and how safe it is to spin higher than the "recommended" rpm. True story on the 143 vs 160 stats but that shouldn't change anything other than where the temp is regulated- the behavior of the temp under load should not change. |
AAM196
I never took a look to see what thermostat my boat has but I'd suspect HW is right...
Seb, mine idles at 160F but running wot for a few mins mine dips even cooler maybe 158ish. I'd check your water pump and hoses... make sure it is sealed up well and you have the right impeller in. As far as running wide open of course pulling out I roll throttle down to the floor then I back to the desired speed. for me footing is typically around 3800-3900 rpm right around 40.. |
Toertel
I'll check again this weekend and maybe post vid on youtube.
This only happens when I run over 4500 after a longer run at 4000 ish and drops right away once I'm back at 4200 ish. When I run it at 4200, even for extended times, it doesn't change the temp vs idle or ski load. Anyway, once I get the 422 on it, I'll let ya'll know what it did to the speed at comparable rpms |
1994 Sport Nautique
JPASS
My temps fluctuate a bit, but not more than 10-15 degrees.......although its hard to tell with the new temp gauge I recently installed. As long as it never hits 180, I'm not worried.
The graduations make it difficult to get an accurate reading. VDO Gauge |
'92 Correctcraft Ski Nautique
Toertel
JPASS good to know I'm not alone.
Mine stays well below 180 even when I rev it past 4500 |
1994 Sport Nautique
I don’t know that I would agree that it is completely irrelevant. While under most cases where my temp creeps up under high speed runs I find that it is due to a slight deficiency in my cooling system (IE my hi-tech strainer/transmission cooler has some weeds in it) the tune of the engine at wot can significantly effect the heat load of the engine and the ability of the cooling system to react to it. IMHO/limited experience the GT40 engines run relatively lean on the top end compared to the big ol calibrated leaks Trbenj or myself are currently running and that can greatly increase cylinder head temp and show up on the temp gauge. Either way if it gets hot(hotter) at speed you might want to find out why or not run it like that. Check strainer, for belt slippage at high speed, leaks, then impeller, if those are good change the thermostat out/check for other system blockages. Still having an issue check the timing and do some plug chops. If all that is perfect and you still have some high speed high temp issues then look at the circulating pump, I have seen the vanes on cheapo replacements rust off to nothing, and have seen the expensive bronze bidirectional ones where the impeller spun on the shaft internal to the pump. Both of those I only found after I caused massive internal damage to the engine but running it hot wide open – apparently the valves and the pistons aren’t supposed to be in the same place at the same time.
skutsch
I hate that when that happens... |
AAM196
Ok... just out on lake tinkering with perfect pass etc... and decided to calibrate to gps and I found everything dead on at 34.2 mph and 36 mph but I found the paddle wheel was lying to me wot and showing 47.2 yet the fastest I read on gps was toggling between 45 and 46. again I am at 2461ft above sea level if that matters. Crazy that the airguide was more accurate.
So I wonder if replacing the paddle wheel would help increase the accuracy. At 36 mph everything just sounds and feels right on that boat! |
M3Fan
At higher speeds the paddle wheel is really just informational which is why it wasn't used as a speed input for anything under wakeboard speeds in the pre-SG PP versions. Upgrade to SG? At 36 everything feels right because that's exactly what the boat was designed to do primarily. Pull tournament skiers through the course at 36mph/58kph straight and true. |
AAM196
How does star gazer deal with river currents or do you just have to calculate manually?
quinner
My TSC2 206 has been clocked at over 80mph and that's a fact, ask Paul Gundriver, Joe in NY or Timmy, they can all verify!!
skutsch
That was going backwards too. Would have been faster cept for that pesky log... |
IAughtNaut
Why do you think he didn't bring his boat this year? Damn campground hasn't removed that log yet.
Think about this! It will show actual speed on the water! You are not flying an airplane! |
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3750 |
If the river is flowing at 3 mph it will affect your GPS, just run both directions on the river and average your speed with GPS.
As far as heating up while running hard make sure your timing is adjusted properly. A couple degree's too much can easily heat up the heads or if more advanced burn a piston. I know the Chevy blocks don't want more than 36-37 degree's or with Vortec heads more like 28 degree's timing at full throttle above 3,000 rpm. Fords are close to those numbers but I don't know for sure. You can check this with a set back timing light, they have a dial that lets you check the timing at various RPM, timing at idle is not nearly as important as proper timing at 3,000-3,500 RPM. |
AAM196
Peter.. rivers have currents.. so yes.. it is like flying an airplane in a way. WINK. If I have the speed set to 36... wouldn't it pull we thru course up river at 39 and down at 33? So I guess what I am asking is for the extra 1k I am spending, does it have a setting that automatically calculates this for me. |
Kind of like landing an hour early on a 5 hour flight because you get a favorable tail wind.
scootdogydog
remember, they work off GPS, so set at 36 will get you to 36...however, for WOT, current will make it go faster, so average them to get an accurate number.
