  New Posts New Posts RSS Feed - Speaker Wiring
Speaker Wiring
jakes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jakes Quote  Post ReplyReply Direct Link To This Post Topic: Speaker Wiring
    Posted: August-27-2014 at 8:00pm
So I was upgrading the stereo in my 2002 SANTE, The speaker wire from various parts of the boat seems to come in light or dark grey one wire is solid the other wire has black stripe.
I assumed, that a same color wire one stripped one solid was a neg / pos pair. But upon connecting them that way i got no sound.
Is actually that a light dark is a neg positive pair?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: August-27-2014 at 8:33pm
Not sure what the standard is in radio installation as far as color coding but your volt meter won't lie....if you have one that is..
TX Foilhead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: August-28-2014 at 9:39am
Speaker should work either way the wire is plugged in, reversing it only changes the phase.
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: August-28-2014 at 12:40pm
One thing that Planet Nautique has, that we don't, is some of the "later" model wiring diagrams, at least a sampling in the 2000s.
http://www.planetnautique.com/vb3/content.php?59
I was curious so I poked around myself on some of the 2003 stereo diagrams (no 2002 available but should be similar).
Looks like you're right as far as the speaker wire coloring. Probably either the speaker is dead or the stereo/amp is not putting out. Check any applicable fuses.
