  New Posts New Posts RSS Feed - transmission
transmission
jakebean View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jakebean Quote  Post ReplyReply Direct Link To This Post Topic: transmission
    Posted: August-29-2014 at 5:30pm
I have a 84 ski supreme for 8 years now love the boat .while at the lake I lost neutral .took it to the transmission guys . they say all the seal and clutches r good . has anyone ever run into this problem before r know how to fix it.
backfoot100 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote backfoot100 Quote  Post ReplyReply Direct Link To This Post Posted: August-29-2014 at 6:20pm
Explain what lost neutral is. Lost forward or reverse, that I understand. Lost neutral makes no sense.
If you took it to tranny guys, I assume you pulled it out then or did you just take the boat to tranny guys?
Need more information to be able to help.
Eddie
baitkiller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baitkiller Quote  Post ReplyReply Direct Link To This Post Posted: August-29-2014 at 7:38pm
Lost neutral is what happens when the clutch packs weld themselves together,
If you cant turn the prop shaft(engine off) it's over. Time to re-build it. No biggie, most of us have done it or had it done.
