176 ideal prop? |
Page 12> |
Frankenotter ![]() Platinum Member ![]() ![]() Joined: August-26-2012 Location: Milwaukee Status: Offline Points: 1072 |
![]() ![]() ![]() ![]() ![]() Posted: September-28-2014 at 7:33am |
Thanks Tim. I think I'll bring the Rpm a back down a little. I think with a new prop and a little carb tuning it will be a 45mph boat. For a little guy with a 240hp and over 1000 hr that's not bad.
1999 Ski Nautique 196
skutsch ![]() Grand Poobah ![]() ![]() Joined: June-19-2008 Location: Racine, WI Status: Offline Points: 2874 |
Tim as always, you are 100% correct, but that old prop needs some time with a couple of hammers and some heat, it is pretty "out of shapes."
I agree with the assessment of the 1442, but we thought it would be fun to throw it on their just for chits and giggles. |
TRBenj ![]() Grand Poobah ![]() ![]() Joined: June-29-2005 Location: NWCT Status: Offline Points: 21210 |
Steve, the 1442 will turn 200rpm higher than the 422 so it would be going in the wrong direction.
All of the "tired" props I've seen tend to lose efficiency at higher revs, meaning they allow rpm to climb higher without speed going up, presumably due to blade flex or some other issue. By holding rpm down at 4200 makes me think it's towards the steep (pitch) range of its tolerance and keeping the engine from reaching optimal rpm but I wouldn't call it tired. Just an older design that less precise and not a great performer. |
I know you're just busting chops, but I'll bite.
Taken out of context... I always recommend spinning the engine at max rated rpm (generally where it makes peak power) at a minimum, preferably exceeding it by 100-200rpm. For a 240hp PCM, the max recommended rpm is 4400, so 4400-4600 is the window, with 4500-4600 being the ultimate goal. You won't hurt anything spinning it at 4700-4800 but if there's a good prop out there that can knock the revs back to the range i just stated, you can gain a little bit of performance as well as some efficiency. I say "spin it to win it" to those afraid to exceed max recommended rpm for fear of "breaking things" or some such nonsense. Over propping to keep revs below max rpm is detrimental to both performance AND reliability as putting a large prop that loads down the engine is harder on components than over revving (slightly). |
Hollywood ![]() Moderator Group ![]() ![]() Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13523 |
wat
That Navionics App is cool!
Not 100% sure the tach is correct. It was my fault we had to shut it down. I should not have gone along. I told him to drop me off and make some passes on his own, but he would having nothing of it. He'll get some better data on a flat inland lake and I won't be with him. I also think that 14x16 is a VERY tired prop. I also offered up my 1442, we just have to get it off the Sport. AND I will give him one of my portable GPS's (which I forgot to take with us this trip). |
Get yourself a real GPS (or at least download the navionics app) and hold the throttle down a little longer. A 400rpm differential seems a little on the high side for a 176. If you're really pulling the 422 at 4700-4800, then you might want a 668 after all... I'm surprised the revs are so different from the 14x16. Ideally, you really want to turn 4600 or just below.
Today Steve loaned me his 422 and I took her for a test run after timing it last night.
We got 4700 RPM at 43mph. That speed was measured on a cell phone app and I had to back the throttle down after a few seconds (rollers on Lake Michigan). I think this is the sweet spot of the boat that Zach was referring to. I noticed a reduction in vibration and now I just have to ski it to check the hole shot. I think I have to adjust the carb now after changing the timing, but I'll post more stats when I get them. Cheers! Chris |
I tried Zack,we came in kinda last minute for a funeral Saturday and left Sunday morning :(
phatsat67 ![]() Grand Poobah ![]() Joined: March-13-2006 Location: Indiana Status: Offline Points: 6157 |
Gary! How dare you!
Please do.
Also, if you get a chance, can you confirm top speed with a GPS? |
skierox ![]() Senior Member ![]() ![]() Joined: November-07-2006 Location: United States Status: Offline Points: 293 |
I have a 1996 Ski 176. I switched from a three blade to a four blade this summer. This is my first season with the boat. It seemed to me that top end is around 45.I can look at what prop is on the boat.
If it makes you guy's feel any better,I was in Indy on the 6th
Me Either!!
You were here and you didn't call?
Can somebody tell Zach I'm not speaking to him |
Gotta make sure she's making full power. I was just up on lake Nagawika this weekend. I should have given you a heads up.
I haven't check the timing since I bought it. It has been running really smooth since rebuilding the carb last year, but I think its time for a timing check. The hole shot has been noticeably slower this year. |
IAughtNaut ![]() Grand Poobah ![]() ![]() Joined: August-22-2010 Location: TN Status: Offline Points: 2568 |
Sorry, that was a typo. The prop I posted pictures of here is what I've always had on the boat. The spare at GL was an OJ 12x17 4 blade. |
Sounds like you got a plan, my need was to just waste some time, you go take care of your stuff! I'd ride along with you, but the boss will have my head if she comes back from work and I am out playing with boats, and trust me, it won't take much to take the head off with the headstart I have given it... |
Like I said I was very impressed with that 17'6". By feel I guess it was moving along at 45+.
I vote give CQ a visit and run a 422 for testing purposes. Who knows if the prop on your boat is healthy or not. Have to checked total timing advance? The 17'6" with the 668 was fresh off of a carburetor tune and a timing setting. I think I dialed it in around 32-34 degrees which is my typical all in I go with on a stocker. It wasn't running to well and required a long warm up before it could operate so I checked it all and set it to my preference IE timing/idle screws/new choke spring installed. I agree with Tim's memory in that you had a 13x17 at GL which I think I confirmed with CC was the factory offering on a 17'6" but my memory could be getting foggy. |
Chris, what's on the boat now- a 3-blade or 4-blade? Confirm the dimensions on your spare- if be amazed if it only has 14" of pitch. $5 says it had 17", can't recall if it's 12" or 13" diam... But that would have been the original prop on a 176, not the 14x16- at least based on what I've been able to gather.
Tim I think the prop you remember from GL was my spare 4 blade OJ 12 17.
I've never used it. Lets make it happen Quinner. Ill plan on heading down by you in the afternoon and maybe we can get a few runs in? Steve, are we still on for Thursday? EDIT |
Wake should not change based on blade count, I'm not sure I buy a table/turbulence difference either. The latter can be impacted (along with rooster firmness) by props that run different rpm at a given speed (higher rpm = firmer/harsher), but blade count shouldn't factor in much. Props of different style (Oj vs acme, for instance) may cause changes to boat attitude depending on how much stern lift they generate (which in turn plants the nose, distributing the boats weight over a larger surface and makin the wake slightly smaller- at the expense of top end speed), but all of the acmes we are discussing are similar in design and shouldn't change the boats attitude in a measurable way.
Like I said above, there is no 3-blade equivalent to the 422 or 668, only ones that have (incrementally) less pitch. I would not choose a prop based on blade count unless all else were equal- in which case I generally prefer 3-blades on our lighter direct drives. Matching pitch to wot is a more important consideration though, IMHO. |
CQ, I am pretty sure you are thinking of the 1442 - that is what I noticed when I switched from the 422, plus 1 mph. I was also pretty surprised at the change in rooster tail, seem to get a lot smaller, but at the cost of a lot more turbulent bubbles back in where you foot. I think I would stick with the 422 for footing, even though it is a little slower, and go with the 1442 for slalom, especially shortline. Of course why would anyone try to ski the course shortline behind my barge... |
And collecting oil and toxic waste out of the Milwaukee River... |
Page 12> |
