  New Posts New Posts RSS Feed - Help with Holley
Help with Holley
jblocal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jblocal Quote  Post ReplyReply Direct Link To This Post Topic: Help with Holley
    Posted: October-02-2014 at 10:06pm
I had a vac leak on my spacer gasket so I pulled the carb a Holley 4160. I replaced both gaskets and put back on and ran boat in yard. Idle was so low it was almost stalling. I had to turn the idle screw a full rotation to get the idle about 700. I turned my air mixture screws in all the way in and that's where engine kinda stumbled but would still run. I know this means I have a bad power valve. Looking for a little input before I go tearing into it. The carb is about 3 years old with around 550hr. Ran great last trip.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: October-03-2014 at 9:55am
They changed the PV design a while back to prevent backfire damage, so at 3 yrs old, that probably isn't the cause. The idle speed adjustment may be causing it to run on the transfer slots, hence poor response from the mixture adj screws. You may still have a vacuum leak somewhere else.
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: October-03-2014 at 10:31am
Check your initial timing. If it is too retarded it will cause you to have the throttle plates too far open to run off the idle circuits at idle rpm.
If it ran fine before I doubt that is the issue unless the dizzy slipped some how.
My bet might be the idle circuits are plugged up somehow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jblocal Quote  Post ReplyReply Direct Link To This Post Posted: October-03-2014 at 7:12pm
Thanks for the response. Maybe something got in there when I was cleaning off the old gasket. Any tips on cleaning the idle circuits?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jblocal Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2014 at 7:25pm
Today I sprayed some carb cleaner down the idle circuits and hit them with compressed air right after. Did it multiple times. I ran the engine and it didn't help at all. No vac leak anywhere. Maybe when I was scraping old gasket off a little piece got somewhere it shouldn't be? Would breaking down the carb and cleaning it allow me to get the idle circuits better? This is all a learning experience for me and any advice is greatly appreciated!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: October-05-2014 at 11:25am
Yes, taking the carb apart & running thin wire thru the small passages is the best way to confirm that there are no plugs. The spray isn't very effective.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jblocal Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2014 at 2:24pm
Ordered carb rebuild kit off skidim. Took apart carb cleaned everything real good. All the passages seemed real clean as carb cleaner with a straw blew freely through everything even through idle discharge hole. Transfer slot looked correct. Replaced power valve with 2.5 which was in there. I could spin the small end on the old power valve read somewhere this means it's bad.? Replaced accel pump diaphragm. I didn't pull off the secondary housing didn't think was necessary. I put back on and ran boat in yard and idle mix screws were not responsive I could still spin 1 side all the way in before it responded. The other side started to respond maybe 1/8 turn out. Pulled carb a second time and cleaned passages again and same problem. Kinda frustrated now as I feel stuck and been dying to go fish.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jblocal Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2014 at 2:28pm
Forgot to mention couldn't find any vac leaks and timing is good.
Here is spacer for my carb never seen any like this. It's been on here since I had boat and everything ran great.
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2014 at 2:29pm
Don't overlook the base gaskets; also some are much better than others. Wedge plate?
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2014 at 2:37pm
Most are running a 6.5 PV but I don't think that's your problem. Never seen the wedge plate mounted that way either I wonder if you try turning it over.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jblocal Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2014 at 4:18pm
I think it's just a spacer. There is no difference in height. It has some oil in reservoir from the pcv valve. There is a series of baffles in the channel that flows to the front of spacer. The gaskets underneath carb are new. I'll give it a flip and see what happens.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jblocal Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2014 at 4:22pm
The spacer has always been this way since I bought the boat. It originally had a ab carter on it though. Been running the holley on it like this since I bought it new 3 yr ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jblocal Quote  Post ReplyReply Direct Link To This Post Posted: October-12-2014 at 4:33pm
Here's a better pic of spacer you can see a little bit of oil on the right side. There's a notch on spacer where it vents to the front bores. Forgot to mention I always have run the 2.5 pv and never had a power issue on my Fishnautique.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jblocal Quote  Post ReplyReply Direct Link To This Post Posted: October-13-2014 at 9:54pm
Update:
Pulled the carb off for a 3rd time tore it apart and cleaned it again. I was messing with secondary butterflys and it wouldn't move so I gave it a good push and it popped open a little bit. Thought maybe I broke it. Upon further inspection everything looked ok. Put it back together and ran boat. Finally my idle mix screws are responding and got a real nice idle. Not sure what ended up being the problem? If it had something to do with secondary butterfly's being stuck or if I just finally got a clog free? Going to water test this week.
