  New Posts New Posts RSS Feed - Exhaust manifold bolts torque
John Pirrung View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Pirrung Quote  Post ReplyReply Direct Link To This Post Topic: Exhaust manifold bolts torque
    Posted: October-24-2014 at 11:05pm
Put a new exhaust manifold gasket on my 86 SN 351 PCM. What is the torque specs for the bolts? I do know it is a good idea to tighten them from the center on out.     Thanks!
John Pirrung
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: October-24-2014 at 11:26pm
I don't know but I'd guess 20 and you'll be safe.
Got your anti seize?
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Pirrung Quote  Post ReplyReply Direct Link To This Post Posted: October-24-2014 at 11:58pm
Yes I do have anti seize, thanks for the info.
John Pirrung
Frankenotter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Frankenotter Quote  Post ReplyReply Direct Link To This Post Posted: October-25-2014 at 12:39am
Here is a link someone sent me when I asked the same question.
Hope that helps.
Chris
torque
1999 Ski Nautique 196
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-25-2014 at 12:43am
John,
To be sure, I just looked at my machinists handbook. 20 may be on the high side considering the lube (anti seize) and a couple ft. lbs. high if you are using stainless. I'd shoot for 18 to 19.
The link above is the chart for dry (no lube) threads.
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: October-26-2014 at 9:56am
I ran a bottoming tap in those and rinsed with light oil. I've had good results with stainless, but it hasn't been 'left alone' for 10 years either. I'm also fortunate to have a real hardware store here. Not all bolts are created equally; even in the same class. Our big boxes don't carry American made HW. Also, a threaded stud(name Pete?) makes for a great 3rd hand. I use 2, but put 'em in the shallow bosses.
It hasn't been taken apart in a while...
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: October-26-2014 at 10:10am
Originally posted by BuffaloBFN BuffaloBFN wrote:
I ran a bottoming tap in those and rinsed with light oil. Also, a threaded stud(name Pete?) makes for a great 3rd hand. I use 2, but put 'em in the shallow bosses.
I had to re-read this because what I saw was you were calling Pete a stud.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: October-26-2014 at 10:18am
Isn't he?
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-26-2014 at 10:23am
A stainless socket head cap screw will have a tensile of 70,000 ether in a 18-8 or 316 material. This tensile is between a grade 2 and a grade 5. Use the torque chart accordingly if you can't find a specific one for stainless.
A "stud"! Well, maybe in my younger days but I was never "threaded"!
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Pirrung Quote  Post ReplyReply Direct Link To This Post Posted: October-29-2014 at 12:18am
Thanks for all the help. Exhaust manifold gasket installed, new electric choke, fogged engine, new spark plugs,changed oil & filter, drained block,put in RV antifreeze, cleaned bilge,washed hull,started to wax.Have been busy the last few nights, trying to beat the weather. Calling for a low of 27 degrees Halloween night!!! Raw water pump leaking around the shaft, need to rebuild this winter.
John Pirrung
bufafiller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bufafiller Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2014 at 11:53pm
Marco and Hassan are having a tour with their teacher David, and Hassan tips the guide a little too much…Tour Guide: If you found my words helpful and interesting, please feel free to leave a few cents or dollars. Thank you.Marco: How much did you tip him, Hassan?Hassan: I gave him a $100 bill.David: Really Hassan, that’s ridiculous! You can’t give someone a $100 tip!Hassan: I’m sorry my teacher. For me, money is rubbish; and what do you do with rubbish? You throw it away.Marco: If you’ve got any more of that sort of rubbish, Hassan, you can always throw it at me.Hassan: Not at you, Marco, you are my friend.
