  New Posts New Posts RSS Feed - learning to barefoot
 Post Reply Post Reply Page    <1 119120121122123 152>
 Rating: Topic Rating: 2 Votes, Average 5.00  Topic Search Topic Search  Topic Options Topic Options
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCH20SKIER Quote  Post ReplyReply Direct Link To This Post Posted: November-14-2014 at 12:11pm
^^ HW is correct- it was a goof pull for Carl while I was working on my LLBD's. When behind the BFN the set up is the fly high pole with a 80' line.
NautiqueNut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NautiqueNut Quote  Post ReplyReply Direct Link To This Post Posted: November-14-2014 at 7:55pm
Kevin, ok 70'off the tower with a 20' boat put's you about 60' off the back of the boat. Greg say's 80' line. same problem in my opinion. To much prop wash and turbulence. As far as Carl's run beautiful LLDW tumble turn start, I can see how the tower can keep you up and out with more ease with that high angle. But what other advantage's are there with the tower? Also rope length seems still to short, aren't you beating yourself to death once up with the short line? Granted the tower will give you lift along with the short line for deep water starts. But after that the party is over. I guess its all what you are used to. As far as age and possibly being dated, no argument their. You guy's don't need my opinion just thought I would chime in.
It was not to late for my 78
!978 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCH20SKIER Quote  Post ReplyReply Direct Link To This Post Posted: November-14-2014 at 8:40pm
Lisa,
No worries. Actually with the BFN it is not so bad @ 80'. The flyhigh / tower are great for lift and help to increase duration of your runs. Glad you chimed in - that is why we post for people to laugh, cry, cringe and ask for more videos......
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: November-14-2014 at 10:07pm
Skiing behind the boat, 90-100' is a good idea. Whatever gets you behind the rooster tail.
3-event trick and wake, done in the curl, is better at 70-80'
GlassSeeker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: November-15-2014 at 1:03am
Seb,
I think that your kfs is just too close to being a standard
Sideslide...even the trick description of a sideslide does not require the feet to be even...just turned 90 degrees(+)...so its still a sideslide but I appreciate your work at inventing something new. This is only my opinion though which does not count for much of anything....I would call it stealing second base.
This is the life
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: November-15-2014 at 1:12am
Originally posted by torchred55 torchred55 wrote:
Take a crappy slalom ski and remove the toe piece of the front boot. Once the boat is up to speed, place your rear foot in the water. Get enough pressure on the foot in the water to ease up on the foot that is still tucked into the boot heel, your foot will slide right off the front of the ski. Once your second foot hits the water, you'll have to adjust for spray and distance between feet. That's how we learned it in the late 70's before suits, wake boards and booms were popular. Best of luck and have fun! P.S. - when going down, TUCK & ROLL!
There are lots of better easier safer ways to learn to foot than stepping off of a ski. Its 2014. Gas was like 60 cents a gallon back in the 70's.
This is the life
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCH20SKIER Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2014 at 8:05am
Season over for me - partial rotator cuff tear in right shoulder. It will be PT for the next ~ 8 weeks then see what happens. Will look at this as an opportunity to get this taken care of and prepare to go visit John and Eddie early next year.
BTW, I will be behind the wheel of tow boat for this years New Years Day Barefoot Tournament on Lake Norman located in Moorseville NC. Lets get a CCFAN contingent together to take on those who support the "other" brand boats......
IAughtNaut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IAughtNaut Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2014 at 12:05pm
Greg that sucks? you don't get to defend your best Wipeout trophy?
bring the ruckus
2000 Pro Air
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCH20SKIER Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2014 at 12:42pm
Kind of sucks - tough to do much of anything that requires raising the arm overhead or backwards.
No chance of repeating as the winner of the annual faceplant award - but heck, grab Jackie and come give this a try. Lots of fun times and great people to hang with when not on the water.
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2014 at 12:46pm
That sucks Greg! ski injury?
rest and it will heal!
Fortunately I did some rest and my waist pain has gone for some time.
So far no pain while barefooting or playing tennis.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCH20SKIER Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2014 at 10:15pm
Kap
I would say yes as a result of skiing. Not sure but thinking that I went into the water baccerds while still having the handle in my hand but not sure. Do know that it was on my last trip out in October
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2014 at 10:40pm
Originally posted by IAughtNaut IAughtNaut wrote:
... you don't get to defend your best Wipeout trophy?
Hmmmm. I just might have to go over to try and steal the faceplant trophy from Greg. I have an in with the driver.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCH20SKIER Quote  Post ReplyReply Direct Link To This Post Posted: November-19-2014 at 8:15am
Larry,
I am hoping that you make the trek over this year - goes without saying that the family is welcome to spend the night at our place and ride up with us mid morning.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: December-08-2014 at 7:43pm
new flip turn ski, a cut down EP Wayne Grimditch
Johnny's first flip turn tries
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: December-08-2014 at 7:51pm
absolutely no barefooting but i can watch stuff like this all day. it's mostly people falling off rowboats, with a random bikini hula-hoop contest squeezed in at the end.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: December-09-2014 at 6:57pm
nice HW!
now to barefooting!
sunday rained during the day, no boat in the afternoon, so we had the river to ourselves.
decided to go to the big canal instead of regular tiny river I ski on, which is narrow for LL.
with that in mind and the double stack pylon, I decided to try LLBD, last time I tried them was at the WBC on april.
Over I was able to do 2 nice runs on shoes.
first run planted to soon,
second run planted to soon,
third run plane, bounce, let go...
fourth run plane, planted, wait wait, got pulled forward
Fifth run video!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: December-09-2014 at 7:03pm
Absolutely the most out of control LLBD I have ever seen but a win is a win! LMAO
Interested in hearing your own critique after watching the video. I'm sure it was a battle and the best you could do from the other end of the line at the time. This is a great learning tool for yourself, and others.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: December-09-2014 at 7:08pm
Lol the split over the wake was terrific! Great perseverance on that one haha.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: December-09-2014 at 7:16pm
Yes the split is awesome!
probably next try will be more in control..straight boat and more speed...
skutsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skutsch Quote  Post ReplyReply Direct Link To This Post Posted: December-09-2014 at 7:18pm
HW - nice step off right into the glass!
Jonny - EVERYONE of those wipeouts, actually almost every wipeout I see now just hurt - I feel them, every single one - is that weird?
Seb - AWESOME - did you have a cup as you were laying your balls right on the pointy part of the wake - ouch! Great run though, when do you get out to try another?
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: December-09-2014 at 7:20pm
I think the wider the legs, more control while dragging but make it harder to stand up, then when I felt I had enough speed Is when I was thinking, hes you are to wide, try to clese the legs...
to many thing going on back there...I even bite my inner cheek, ended up spitting blood!
but man what a ride!
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: December-09-2014 at 7:22pm
No cup Steve! shorts and suit, felt no pain in the nuts, more concern in chin and mouth protection now...
Post Options Post Options   Thanks (0) Thanks(0)   Quote skutsch Quote  Post ReplyReply Direct Link To This Post Posted: December-09-2014 at 7:25pm
Yep, I hear that, more then one of my attempts I remember banging my teeth or biting my lips. One more thing to think about back there, keep your jaw tight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: December-09-2014 at 7:33pm
KBS
kapla ball slide
Post Options Post Options   Thanks (0) Thanks(0)   Quote skutsch Quote  Post ReplyReply Direct Link To This Post Posted: December-09-2014 at 7:55pm
KBS
kapla ball slide
HA HA HA!!! Seb keeps trying to create these new barefoot tricks and he already has two - The Superman and the KBS!!!
barefootjames View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote barefootjames Quote  Post ReplyReply Direct Link To This Post Posted: December-09-2014 at 8:40pm
Nice run!
I used a store bought bite guard for years of footin.
Now I use a dentist issued dental football bite guard. That lasted one year of foilin. Next year I will use my nightly dental bite guard for thee foilin.
All of the years of footin, backwards, and forwards never wore a cup. Never had a severe ball buster.
2005 Super Air Nautique Team Edition Blue/Black Reverse Color Hull
1997 Ski Nautique White/Blue/Black Sold
1997 Ski Nautique White/Black - Sold
1991 Barefoot Nautique White/Medium Blue/Light Blue - Sold
198
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: December-09-2014 at 9:31pm
Nice video......I agree with the others....no sore balls on the wakeout huh? Nice work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: December-09-2014 at 11:13pm
KBS. That's great. Eat your heart out ADV. One of the greater pains I had when learning was in my jaw/jowls as well. Fixed itself without really even thinking about it as my form improved. I think the key to that is to really crank your head up so you are looking at the sky and not into your own rooster tail.
jbear View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbear Quote  Post ReplyReply Direct Link To This Post Posted: December-10-2014 at 1:57am
all I got to say is.....wow.
congrats too Kap!
john
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: December-10-2014 at 3:02am
Originally posted by 75 Tique 75 Tique wrote:
One of the greater pains I had when learning was in my jaw/jowls as well. I think the key to that is to really crank your head up so you are looking at the sky and not into your own rooster tail.
X2
