  New Posts New Posts RSS Feed - Trailer Light Testing
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Topic: Trailer Light Testing
    Posted: December-12-2014 at 12:42am
I needed to chase a light problem on one of my trailers, and had it inside to work on it, no vehicle attached. To power up the lights I connected a battery charger, at 2 amp output setting, positive to the pin I wanted to power up, negative to the frame. It worked, had never done that before.
Can I do any damage powering the circuits with the un-fused output from the charger? If not, pretty handy way to test things.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2014 at 12:47am
David,
No damage to the trailer. If there is a short to the trailer frame (ground), the battery charger is protected typically by a auto resetting circuit breaker.
So, what did you find was the problem with the trailer lights?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2014 at 1:27am
Well, as suspected, bad ground, but also blown bulb. I had cleaned up and re-connected the ground with no luck, bulb looked good, but then when I swapped bulbs I realized it had been both problems at once.
This is on a utility trailer, not set up with a good ground connection with just a sheet metal screw threaded into a drilled hole, sharp end sticking out the other side. I picked up some 10-24 stainless bolts, nuts, flats, and locks and will through bolt the ground.
CrazyCanuck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrazyCanuck Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2014 at 1:46am
I kept the old car battery from the last time I bought a new one for my van. I trickle charge it once in a while and use it for the tent trailer when camping. Its great for testing stuff like that.
https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcRtW3vJrMHLdqBzndt9VX3oOpBuRopGlzKq9Ea7pAO7wnTuoD8E8g
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2014 at 2:07am
I didn't know if hooking directly to a battery could blow the lights, all that amperage available with no fuse. Figured the charger at least had limited output.
Electrical has never been my strong suit! I get by, but barely.
tullfooter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tullfooter Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2014 at 9:47am
+1
'85 BFN
'90 BFN
White Lake, Michigan
Post Options Post Options   Thanks (0) Thanks(0)   Quote tullfooter Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2014 at 9:49am
Also nice to make a pigtail out of a flat 5 or round 7 connector with alligator clips to connect to the battery, and to the trailer plug.
'85 BFN
'90 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2014 at 10:17am
I clipped the positive from the charger to a very small allen wrench, and was able to probe each trailer side connector with that.
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2014 at 11:08am
Ehhhh, electrical stuff is easy. Most folks over think it. It's just a time consuming road map you need to take all of the roads to find the problem.
Glad to hear you have a successful test bed and functioning lights now!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2014 at 11:26am
Thanks Zach. I tend to feel that I'm not over-thinking, it's more that I'm under-intelligencing!
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2014 at 11:54am
Ha common you're a smart guy! There's ground, power, and voltage. You need a test light and a multi meter and you can test about anything besides a wire load test on our boats/trailers.
Grab a beer and enjoy your finished handy work :D
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2014 at 12:36pm
I know, I can get it done when needed. Just has never come naturally to me, I really realize it when I watch someone who is good. A guy I work with is extremely talented, and a friend who works on trucks for me is as well, I enjoy watching them work.
After the Thanksgiving storm had ramped up I went to hook up my plow, and nothing. After chasing the problem and one call to a friend I was able to get it fixed, so felt pretty good about that, and now I know what to do for the future. It's all just a learning adventure!
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2014 at 12:38pm
What type of plow rig you running? We always had Dodges with Meyer plows and now we have an older Dodge with an older Boss.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2014 at 12:43pm
But Zach, most VOM's have an amperage port and setting up to 20 amps. The only issue with cheap VOM's is they may only read AC amps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2014 at 12:45pm
Fisher Minute Mount 1 on a '98 GMC 2500 extended cab long bed 6.5 diesel.
skutsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skutsch Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2014 at 12:47pm
Those Boss plows are solid, we have a Power - V up at the Tree farm on an old F-250, The V is great for opening up the roads after a big snow, that rig will go through anything. Oh and when you get your truck start, you can use the V to push yourself backwards...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2014 at 1:34pm
Just the same as doing telephone only it's over longer distances and higher voltages. And worse working conditions. So I guess it isn't the same after all. After doing it for so long I still prefer analog over a digital meter,you can also test a fiber "pair" with a analog meter too.
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2014 at 1:48pm
IMHO, DC, especially 12v on a trailer is the hardest electrical system to work on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2014 at 1:52pm
Compared to?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2014 at 2:01pm
Space shuttle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2014 at 2:14pm
David,
Any issues with the fuel solenoid module? I'm on my 4th OEM Stanadyne in 290K miles. The last one was supposed to be the gray color "fixed" unit. It's starting to go! I went through an after market one too. I have a feeling they need to get the amp meter out and check the load on the transistor in the module! To make it worse, the intake manifold needs to be removed to get to the damn thing!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2014 at 3:30pm
Pete, subject I enjoy, I'm on my 3rd 6.5 diesel and a friend of mine works on them and has bought/sold/run another 6 or 7.
The PMD or FSD can't stay mounted to the injection pump. GM mounted it there because they thought the fuel flow would cool the PMD, but when you stop the engine they heat soak and fail. GM replaced something like a half million perfectly good injection pumps because they couldn't figure this out, but the aftermarket had it figured out in the early 2000's. Anyway, you need to get an extension harness, mount the module on an aluminum heat sink, and then mount it in one of the ventilation holes in the front bumper. That solves the problem, though being honest I carry a spare PMD with me just in case. Go to Heath Diesel (my favorite but expensive), Kennedy Diesel, or a few other places to buy the PMD all mounted with a harness, they aren't cheap though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2014 at 3:39pm
Uhh o, don't let Workman see your plow rig. He will be smitten!!
Hows that old 6.5 run? My uncle used to run a good looking one with a Sno Way on it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2014 at 3:41pm
Chevys in the rust belt make their own ventilation holes and I've seen Petes he could mount it anywhere!
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2014 at 3:52pm
Better be careful with that shiny new Avalanche Gary ;).
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2014 at 4:12pm
You're right about that Gary, rust is a real problem, particularly lower door panels and tailgates. My friend bought an extended cab out of Louisiana, had it trucked up, and we couldn't believe the difference. Bolts came apart easily without penetrating oil or heat, no rust, everything preserved. I think if I buy another one I may look to the south.
Zach, I love these things. The knock on them is no power and they don't stay running. But, if you do a few basic mods and take care of a few GM engineering errors, they run strong and are reliable. I towed a 7,500 lb. trailer without any special towing mods and it pulled it just fine, pulls the boats with ease, runs smooth and starts right up. Plus, because there is not much demand for them, they are cheap to buy. My truck was $1,800 not running (no plow), we had it running 4 hours from when it arrived, I've put around $1,200 or so into it. The plow was $2,500, cost much more than the truck!
Kind of like Correct Crafts .... I just like them. I like 6.5 diesels. I like Cub Cadet garden tractors. Becomes a hobby/habit after a while!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2014 at 4:23pm
5 of them lined up at my friend's house.
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2014 at 4:32pm
Look at that fleet! I hate rust with a passion. One of the reasons I have a newer vehicle and play with boats more now than old cars.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2014 at 4:54pm
Compared to?
Compared to?
Well anything. I'm an independent electrical contractor specializes in concerts/film shoots and industrial. My claims to fame would be working in the sugar mills in south FL where 277 is the control voltage and the motors run 4160 straight from the line. 1200 "Assembly" lines at a steel factory. Did two expansions for Piper Plastics along with rebuilding 2 of their injection units (know them Pete?) prior to wiring their new plant with 10,000 amps 480v. All on my own dollar.DC just doesn't travel well which is frustrating then 12v no matter if it's alternating or not stops at the slightest corrosion or the thinnest layer of paint. With 12v you have to find the problems, 277 and up..... The problem is apparent and easy, often finding you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: December-12-2014 at 5:20pm
Now with the water/salt getting inside the doors, the biggest problem is keeping the latch and window mechanisms running free. I've gotten real good at spraying the CRC 3-36 with the straw the problem points without taking the door panel off.
