  New Posts New Posts RSS Feed - 76 SN Rudder
76 SN Rudder
Tomahawk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tomahawk Quote  Post ReplyReply Direct Link To This Post Topic: 76 SN Rudder
    Posted: January-21-2015 at 9:42am
I need a rudder for a 76 Ski Nautique. I have both parts so repair is an option. Would like feedback on that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-21-2015 at 9:46am
Eric,
Whats wrong with your rudder and port? Repair is an option depending on whats wrong.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tomahawk Quote  Post ReplyReply Direct Link To This Post Posted: January-21-2015 at 9:50am
The rudder is broken in two at the base of the port. most likely part of the accident that damaged the boat. Port does not appear damaged.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-21-2015 at 9:53am
Eric,
Since the rudder shaft is in two pieces, then I'd have to say you do need a new or used rudder. I would not suggest a repair.
What other damage was done to the boat? Pictures?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tomahawk Quote  Post ReplyReply Direct Link To This Post Posted: January-21-2015 at 10:05am
Prop was trashed. significant damage to port side from 6" to almost the wind shield. Need to figure out if drive shaft was damaged.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-21-2015 at 10:10am
Wow! You do have a project ahead of you. Keep us informed and the pictures coming. If the prop was trashed, I'd say there's a good chance the shaft is too. Don't forget the strut ether. On the shaft, I suggest an ARE replacement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tomahawk Quote  Post ReplyReply Direct Link To This Post Posted: January-21-2015 at 10:11am
What is ARE?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-21-2015 at 11:26am
Originally posted by Tomahawk Tomahawk wrote:
What is ARE?
Eric,
The ARE prop shaft is a double taper design. (taper for the prop and taper at the trans coupling) Many here including myself have used it. It greatly reduces R&R of the shaft. The original single taper shaft is a interference fit at the trans coupling that requires heat shrinking the coupling to the shaft. The ARE system cost is about the same you would pay for a single taper.
Here's a link to the ARE explaning how it works.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tomahawk Quote  Post ReplyReply Direct Link To This Post Posted: January-21-2015 at 11:31am
Thank you. Might be another thing to buy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: January-21-2015 at 11:44am
I don't know of any available but in hopes of assisting in your search... You have 2 rudder options. 1)buy a new tabbed rudder... There are a few part numbers to choose from but you want the direct driver version with the 1-1/4" port. $$$. 2) the original rudder is a 11a, and came in most 18'+ direct drive cc's starting in 1970.
ScottZ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScottZ Quote  Post ReplyReply Direct Link To This Post Posted: January-26-2015 at 12:28am
I have a used 11A I will sell you.
Lake Mitchell , AL
1984 Ski Nautique
1972 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScottZ Quote  Post ReplyReply Direct Link To This Post Posted: January-26-2015 at 12:29am
I probably have a strut too.
Lake Mitchell , AL
1984 Ski Nautique
1972 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScottZ Quote  Post ReplyReply Direct Link To This Post Posted: February-04-2015 at 9:03pm
Lake Mitchell , AL
1984 Ski Nautique
1972 Skier
skutsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skutsch Quote  Post ReplyReply Direct Link To This Post Posted: February-04-2015 at 9:11pm
****************** Threadjack Alert ******************
Scott Z !!!!!
Where have you been, have had about 4 boats come up in AL, always looking for somebody down in that area to go look at them. How can there be so many used CC down in that neck of the woods and your the only one on this site - HA!!!
Don't be a stranger... Wait a minute, your dad has my dad's twin Ski Nautique too
****************** End Threadjack   ******************
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScottZ Quote  Post ReplyReply Direct Link To This Post Posted: February-04-2015 at 11:44pm
Let me know if another one come up that you are interested in. We have a tone of them here! I had to go up your way to get my Sport Nautique. The later models are hard to come by.
Lake Mitchell , AL
1984 Ski Nautique
1972 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote skutsch Quote  Post ReplyReply Direct Link To This Post Posted: February-05-2015 at 9:46am
Geez a Sport Nautique too, what year? I have a 98 Sport too - HA! Too Funny. I will keep you in mind. Definitely going to have to meet you some time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScottZ Quote  Post ReplyReply Direct Link To This Post Posted: February-05-2015 at 10:53am
I also have a 79 and 86 Ski Nautique as well.
Lake Mitchell , AL
1984 Ski Nautique
1972 Skier
