Painting the Hull |
ScottZ
Platinum Member Joined: January-20-2004 Location: Clanton, AL Status: Offline Points: 1146 |
Posted: October-15-2004 at 12:47pm |
I'm on the process on sanding imron paint (that is a different color from the hull) off my 1971 Ski Nautique. There is not enough gelcoat left to refinish, so I am given the option of regelcoating or repainting the hull bottom and sides). Can anyone give me a recommendation on what type of paint I should use?
Thanks |
David F
You should use Imron (Dupont's polyurethane enamel) or its equivalent.
kenny g
Senior Member Joined: December-13-2003 Location: United States Status: Offline Points: 318 |
scott,i'm with david.i did the barracuda with imron and love it ! it,s a good hard finish if it's done rite.BUT.. today,there is 2 different types of dupont imron on the market. the 500. and the 500s one is just a cheaper grade,and cost much less. use the better grade and whatever you do.DONOT let anybody tell you you can use lacquer type primer .you'll be wasting your $$$ if you need any help,give me a call 859-824-1740
kenny g
Tim D
Grand Poobah Joined: August-23-2004 Location: United States Status: Offline Points: 2637 |
I repainted my 66 mustang about 12 years ago (it's in the diaires). I didn't use Imron, but it has held up very well. I painted the hull, let it dry for three days, wet sanded, drew my stripes and wording, masked it off and painted the blue and red. Then I let it dry for two days and clear coated everything. I put plenty of hardener in the clear to give it a tough finish. I made sure all the solvent had escaped before overlapping by letting it really dry. Trapped solvent will pop off the clear. I used 3m's masking tape called the edge, it gives excellent hard edge lines. If you ever used vinyl treatment on the interior, be sure to degrease (prep wash)where people might have stepped on the fiberglass or you'll get fish eyes.
Tim D
kenny g
TIM D we are not talking acrylic enamel here.
polyurethane enamel is chemicaly activated.a set amount of paint and activator are used only.unlike acrylics,imron has a short potlife.once it cures,this finish is much harder than acrylic lacquer.but lacquers,and acrylics dull/fade over time,polyurethanes don't.acrylics are thinned,reduced,hardners added,blushing chemicals added [when spraying in damp weather ]at $65 a quart for imron activater,adding more wont do a thing to make the finish any harder. |
kenny g
Tim D
I had to look at the cans, the colors are acylic enamel and the clear is urethane with a hardener or activater or whatever you want to call it. I don't paint cars, only 1 boat. As far as measurements, a body shop told me to put a little extra hardener in but not way too much or it will not cure. The paint I used is not made any more and the Imron is more popular. My sorry choice of words,"plenty" should have been written as precise, exact measurement, don't be short,don't cheat yourself.
Tim D
NAUTI84
Senior Member Joined: June-10-2004 Location: United States Status: Offline Points: 485 |
ScottZ,
A buddy of mine rebuilds old Lyman wood boats. I've seen him redo the entire hull, replacing rotted wood and all the screws. He then has them painted with Awlgrip. http://www.awlgrip.com/ It really comes out looking like a new fiberglass boat. Not sure how expensive or how many people do it, just thought I'd pass it on. Good luck! |
David F
Awlgrip is a brand name (similiar to Dupont). I believe Awlgrip makes a urethane paint similiar to Imron (product name), but I am not certain of its name. Awlgrip specializes in marine finish systems of many types.
