CCF FAQ |
Page <123> |
KRoundy ![]() Platinum Member ![]() ![]() Joined: August-23-2010 Location: Lake Stevens Status: Offline Points: 1704 |
Added the great link about the SN 176 models.
TTT
Could we maybe get a sticky on this? |
Hi Kevin,
I'd like to submit my steering cable write-up I just did: http://www.correctcraftfan.com/forum/forum_posts.asp?TID=31166&title=steering-cable-replacement-with-pictures |
Morfoot ![]() Grand Poobah ![]() ![]() Joined: February-06-2004 Location: South Lanier Status: Offline Points: 5334 |
boardersdad ![]() Senior Member ![]() Joined: June-18-2013 Location: Wisconsin Status: Offline Points: 409 |
Great job; this should be a sticky...
Thanks. I have asked if this could be a sticky before. Does anybody know how to make that happen?
Please consider Motor Oil, Oil Filters, Transmission Fluid. Thanks.
Added a link that shows how to pressure test manifolds.
Added Kris' (Dreaming) write up on fuel tank fittings.
TTT
flipflop ![]() Senior Member ![]() Joined: June-15-2010 Location: usa Status: Offline Points: 187 |
Stuck Prop - Links -
Upgrading my old OJ 4 blade to a refurbished Acme 380. I tried once to remove and it was stuck like a duck in the muck. Did some searching on here and found these two links: Stuck Prop 1 Stuck Prop 2 To add my two cents. I used a regular prop puller and propane torch to heat the hub and it worked fine. I also kept a cup full of ice cubes next to me and placed them just aft the strut to keep the shaft cool and from damaging the strut bearing. Took a couple of minutes before the gun went off. *Let me know if this has been covered or does not belong in the FAQ section. |
flipflop - good add. I'll put these up front.
Kevin |
TTT - This had almost slipped down to page 3.
Don't get it |
Joe was suggesting that Kevin add new information, but doing updates to his original posts, rather than adding new ones. That way all the good, clean, information stays towards the top. |
It's been a labor of love and the idea is to keep all the useful links at the top of this thread (not down here on page 2). Any suggestions for new additions from the CCF family?
TTT - And another plea for a sticky. Please?
Any suggestions for things that should be added?
I would nominate the GT-40 thread:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=25584&title=poor-mans-gt40-diagnosis |
Done.
Added JP's great write-up on how to replace a Pro-Tec system with a DUI system.
A good post by mamigacz on how to remove the primary fuel bowl:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=34538&PID=444268#444268 |
Please make this a sticky... most important thread of all!
We have asked this a lot, but so far have not been able to get the request to "stick". ![]() |
It is now a sticky!
Thank you.................... ![]() |
Here's another good Holley rebuild pictorial write-up from a while back:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=24175&PN=1&title=carb-rebuild-88-2001 |
Woo hoo!!!! Sticky Baby!!!! :)
Added carb rebuild thread above. |
Unless I missed it, here's the thread HW just pulled up - detailed 89 trailer restoration.
Thanks, Pete. That is a great write up. I added it.
Added another trailer restoration thread with information about bunks, side steps and spare tire mounts.
Page <123> |
