  New Posts New Posts RSS Feed - 2001 Brass Strut
2001 Brass Strut
mbshaw88 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mbshaw88 Quote  Post ReplyReply Direct Link To This Post Topic: 2001 Brass Strut
    Posted: April-13-2015 at 6:05pm
Need a straight brass driveshaft strut, no bearing needed, for my 82 SN.
Looks like this
Shipping would be to 60074
Willing to pay $100
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2015 at 7:31am
Matt,
Since you are looking for a "straight" strut, I take it your's is bent. Have you considered having yours straightened? Many have and some have even done it themselves with great results. If you don't have access to a press for the DIY, many prop shops will do it. They bend alloys of copper all day long!
baitkiller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baitkiller Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2015 at 11:20am
Listen to Pete. Unless it is mangled a prop shop should be able to straighten it.
Post up a photo, maybe we can help.
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2015 at 12:27pm
What they said, if you need a pro call these guys
Fox Lake Propeller
1803 Holian Dr., Unit D
Spring Grove, IL 60081
847-587-5600
Post Options Post Options   Thanks (0) Thanks(0)   Quote mbshaw88 Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2015 at 1:50pm
Pete yes mine is bent. You've helped me out with a few posts concerning this incident. The strut seems to have taken the brunt of the damage, showing an angle to one side and a slight twist. I put the shaft on our lathe at work and measured .003" runout on the dial indicator. New cutlass bearing, acme prop, and packing all are awaiting a straight strut so they can be reassembled.
I've tried straightening it at work with a bottle jack in a few different fixtures, but man this thing doesn't want to budge.
I'll talk with Fox Lake Prop and see about dropping this off with them. Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote baitkiller Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2015 at 2:09pm
That is gonna be so easy to fix. I could tell you how to do it yourself but may as well let the prop guys do it right the first time.
Good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mbshaw88 Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2015 at 2:12pm
Yeah I gave it a shot, but at this point I'd rather just pay a shop to do it
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2015 at 7:42pm
Matt,
As mentioned, that's going to be an easy fix. Ideally you should have a hydraulic press. Report back when it's repaired.
Where did you get the .003" runout? As I've mentioned before, just aft of the strut is a common area due to prop hits. The .003 is the limit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mbshaw88 Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2015 at 9:50pm
The .003" was taken just before the prop taper
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2015 at 9:56pm
Matt,
You should be ok with just some very minor vibration. You may not even notice it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mbshaw88 Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2015 at 9:58pm
Great thanks Pete!
