  New Posts New Posts RSS Feed - Need unusual fitting
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Topic: Need unusual fitting
    Posted: May-18-2015 at 7:46pm
I bought a fuel line from DIM and they sent me fittings that do not fit the engine I want to use this on. It's going on a 318 with Carter AFB. This is the fitting they gave me. What I need is the 3/8" JIC 37 tube thread as is shown, but rather than the NPT thread on the end that had the sealant, I need it to be 5/16 inverted tube thread.   Anyone know who might have one of these? A 90 degree would be great, but straight would work also. I can't find one at McMaster Carr.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-18-2015 at 7:57pm
Bruce, a decent auto parts store may be your best bet. The inverted flare fittings are used on brake lines. I found an oddball fitting like that at my local advance this weekend, couldn't find anything online.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: May-18-2015 at 8:00pm
NAPA came up with nothing. I'll try Advance if we have one.
LeftFieldEngineering View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeftFieldEngineering Quote  Post ReplyReply Direct Link To This Post Posted: May-18-2015 at 11:13pm
Could always call Fln-Mar in Holyoke Ma or McGill Hose in East Longmeadow Ma. They were the to go-to hose & fitting suppliers when I worked at my uncles logging outfit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2015 at 10:20am
Thanks, I'll give them a try. First time McMaster Carr has come up empty..
DayTony View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DayTony Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2015 at 11:07am
if mcmastercarr does not have it, than it probably doesn't exist. and your in a parralell dimension.
try here
http://fittingsandadapters.com/
never heard of inverted tube thread but to me maybe sounds like you need AN-?
try here
http://www.speedwaymotors.com/Auto-Meter-3274-Pressure-Gauge-Elbow-Adapter-Fitting-90-Degree-4AN,113903.html
http://www.speedwaymotors.com/Shop/Fittings-AN-Fitting-Couplers/12.html
1988 Barefoot nautique-454
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2015 at 11:21am
I am not sure if AN is the proper thread. Advance auto and SkiDIM both identify the double flare fitting as "inverted flare". No such moniker at McMaster, maybe there's a another proper term? It's the same used on brake lines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DayTony Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2015 at 12:08pm
i know that some carb fuel fittings will allow a pipe thread to thread on because the pitch is close, and i have seen people do this and put tef tape on them which is WRONG. all lines should seat on a flare or flat seal.
I have a carter sitting right here and i think it has what you are describing. now i know what you meant by inverted flare on the CARB side. the male end of this is designed to fit a flared tube with fitting. I dont know that you will get a 90* in that because you can bend the tubing to 90*
is this what you have?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DayTony Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2015 at 12:15pm
i found these so someone must make what you want.
1980nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1980nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2015 at 11:32am
Have you tried a local marina??
Try Summit they have what you need!!!!!
oldcuda View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldcuda Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2015 at 12:03pm
Looks like the same size/style for Quadrajet fuel line.Any place that makes hydraulic lines should be able to hook you up with them.I went to local Napa had them make up straight line and bent to fit from carb to pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2015 at 12:11pm
This is likely going to be something you get from summit racing, They would certainly have an adapter that got from the carb to something more common.
racingnc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote racingnc Quote  Post ReplyReply Direct Link To This Post Posted: May-21-2015 at 9:58am
Home Depot has a compression to pipe fitting in the Watts bay.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-21-2015 at 10:27am
Compression and inverted flare are definitely not the same. I struck out on carb/fuel line fittings at multiple hardware stores.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: May-21-2015 at 11:56am
Have you tired Fastenall? I used them for the elbow on the velvet drive. They have mucho fittings.
