  New Posts New Posts RSS Feed - Support-Literally
Support-Literally
AlfaDon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlfaDon Quote  Post ReplyReply Direct Link To This Post Topic: Support-Literally
    Posted: May-26-2015 at 6:47pm
I need to do some repairs to my trailer, and would like to have better access to the hull for polishing. I'm looking for some suggestions to either use boat stands, or build a cradle of sorts.
If I build a cradle, I'd just duplicate the locations of the trailer bunks. I'm thinking of a support at the stern and another up by the seats, and run a pair of 4 x 6's on their sides between them.
What about if I used stands? I thought I could put a pair at the stern under the stringers, and maybe another pair under the stringers at the front engine mounts.
What do you think?
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2015 at 7:10pm
Don,
3 points. One at the keel just aft of the stem then the two corners on the bottom at the transom. If you don't have any means of lifting the boat with the lifting eyes, the 3 point will make it easier to get the trailer out too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlfaDon Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2015 at 7:18pm
Thanks. That helps, and makes sense.
Do you think an 8" square piece of plywood at the back corners will be sufficient?
On another topic, you made a comment recently on another post about aligning the prop shaft. Is there a write-up someplace on the forum that you could direct me to?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2015 at 7:42pm
Sorry I can't remember the name but I saved this picture because of the supports
workmanship and frankly the boats too. Maybe it will help you out with yours
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2015 at 8:47pm
8x8 is 4x more than plenty.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2015 at 8:53pm
It's getting harder to find. It's in the "New" section but now about halfway down on page 2.
Alignment video
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlfaDon Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2015 at 9:29pm
Thanks guys
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2015 at 9:40pm
Don,
I know there's a link in the FAQ thread in the maintenance section too. Lots of great stuff in that thread. If you have any questions after viewing the alignment video, speak up and we'll answer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlfaDon Quote  Post ReplyReply Direct Link To This Post Posted: May-27-2015 at 4:07am
I remember watching that video a while back closer to when it was recorded. Because all of those points are adjustable, I remember at the time wondering "where do you start" or what"s the reference point? After checking for a bent shaft, do you generally start with the strut and the log as the starting point?   I guess I'd rather not un-bed the strut if it didn't need it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-27-2015 at 7:15am
Don,
The log is a fixed position so you start at the strut. once the shaft is aligned with the log, then the engine is easily adjusted. Yes, the strut can be a PITA but you must start there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlfaDon Quote  Post ReplyReply Direct Link To This Post Posted: June-19-2015 at 2:41am
I've been working like mad, trying to get the boat ready for vacation. I thought I should check in with my progress. I separated the shaft coupling, and then removed the coupling from the shaft. I could tell I had some wobble in the shaft, but couldn't tell exactly where it was. Mostly because of the play if the strut bushings.
So, I got the shaft out, and took it into a repair shop today. Well, repair shop is an understatement. It turned out to be the SF Bay areas leading repair yard. I saw 2-blade sailboat props that were 8" in diameter up to a tug boat that was getting a prop refit, and the things had to be 6' in diameter, if not more. It was pretty impressive.. The machinist was about the nicest guy you could hope for and he takes the shaft and puts it on a lathe (called a Steady Rest) and marks where it's bent. It turns out the the bend starts at the front of the strut, though the tail. It was .005 out at the center of the strut, and .011 out at the tail. The price will be $150 max, and if he can't straighten it, there won't be a charge.
When it comes back, I'll go through the process of making sure it's aligned with the log and the engine.. I've got new bushings coming from Skidim soon.
I have a question about the strut bushings. I have a 2-piece bushing in there now, and that's what's coming in the mail. The aft end of one half is flush with the strut. There's about a 1" gap between the two pieces of bushing, but the forward piece is recessed about a half inch into the strut. Is this correct? I guess that with the recess of the front half, it would collect water to lubricate the bushings.. If I make it flush with the forward end of the strut, the set screw just catches the bushing by 1/4"
Thanks,
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-19-2015 at 7:46am
Don,
I like to keep double bushings as far apart as possible for shaft support. The important one is the aft. Keep it all the way aft. Don't worry about water getting in. It will!
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: June-19-2015 at 11:05am
What Pete said.
I like to put them flush to the front and rear leaving the gap in the center.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: June-19-2015 at 12:32pm
You can drill and tap the strut further forward to put the set screw in a better place too.
