Engine Rotation |
caricoa28
Newbie Joined: June-26-2012 Location: Lodi, Ca Status: Offline Points: 16 |
Posted: May-21-2015 at 1:47am |
So I took my 77 tique to what I thought was a reputable boat mechanic to do a few things cause I have no time. Wiring, new distributor with the pertronix kit, resistor, coil, gauges, and to install a high torque starter. In the end they couldnt get it running because they ordered the wrong starter, and have been rotating my engine in the wrong direction trying to get it to fire. My question is did they screw up my motor? I have a 302 and they thought it was a 351. I dont know why, I specifically asked if they would like to use the original engine book that came with the boat.. they said no.. "we got this". So is the right starter going to fix my problem, or has rotating my engine in the wrong direction by a bunch of idiots ruined my summer? Any advice before they get my nasty message in the morning would be awesome.......
Thanks so much Steve |
Steve
Lodi , Ca |
DayTony
Gold Member Joined: June-30-2013 Location: Salem MA Status: Offline Points: 832 |
Most boat mechanics are far from reputable in my experience. Thats why i work on my own stuff. But there are a few other things to question because everything in these reverse rot. would be different from std rotation for everything you mentioned they were replacing, The distributor gear will be different, in turn the fireing order will be different. and don't forget the oil pump is not pumping in that direction. so you were not oiling when they were "trying" to start it.
SO it all depends how long they were cranking it to try and start whether you may have some oiling issues but i suspect any damage that would have been done to any bearings if any at all would not show its face right away. In other words. till you've paid your bill and moved on. Pistons, valves, etc none of those will have been affected. But if they somehow shoehorned the wrong distributor in there (which i don't think it would even seat but i've never tried) If that's the case there is possibility of cam gear damage running the wrong gear on there. And then the RWP impellar may need to be checked out if it was pushing instead of pulling water. I suggest documenting it all thoroughly if you plan to pursue any real action. Which action that is, i cannot give any real advice on what way to go. If it were me i wouldnt bother with any nasty phone calls i would show up in person, i would not pay a dime and i would drive away with my boat right then and there. Document how everything was when you got it and remove everything they did and do it right. And sell that "wrong" starter on ebay good luck. |
1988 Barefoot nautique-454
Orlando76
Many people spin the motor the wrong way with wrong starter and like mentioned above, doesn't seem to do any significant damage right away. At least it wasn't under load while not getting properly oiled. How'd they get that standard rotation 351 distributor in a backwards 302?! RWP will straighten itself into right direction but at this point, why not pull it and flip the vanes over. Don't feel bad "reputable boat mechanics" screw people all the time, at least you had enough smarts to pick up on it. If you take your boat to a mechanic... Sigh, I hate to say this..... Take it to your local direct drive inboard dealer only.
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5779 |
Have your original MARINE starter rebuilt as they probably used an automotive unit. You don't need a HIGH Torque starter. Tthey also Probably didn't put in a new distributor just a pertronix kit. So you will be ok there as long as you didn't pay for a new one. Once you get the starter I would check the firing order and then give it a crank, it should fire right up. I personally wouldn't expect a problem with the raw water impeller but keep an eye on the temp gauge just to make sure. You will be fine
caricoa28
The only part that they had to order was the starter itself. All the other parts that I had installed I had bought previously but never had time to install myself. the distributor is a mallory, and it came with the kit already installed in it, I just had to take the gear off the old unit and put it on the new distributor to get it to fit correctly. I might not need the high torque starter but I've always wanted one.. I guess thats just me. Anyway, I plan on dropping her off again after I get off work so they can put the correct starter on.. and speak with them about the gauges.. they will be working before I get her back.
Steve
Lodi , Ca |
caricoa28
And thats another thing, when I dropped the boat off I left the hose attachment in the boat for the motor to be ran with hose water, and it WASN"T in the boat when I picked it up.. I wonder how long they were cranking on it without water going to the motor... I would have checked the pump before It went in the water but it WAS brand new. The more I think about it the more I re-affirm that nobody will take care of your things the way you take care of your things..
Steve
Lodi , Ca |
phatsat67
Sounds like you need to start learning to do it yourself. You already sound quite a bit more knowledgeable than the shop you took it to.
caricoa28
Thanks Zach. I have learned a lot since I bought the boat 6 or 7 years ago, and I enjoy working on it. But summer got here too quickly and with my job, I just didnt have the time I wanted to spend on it. I guess lesson learned the hard way. I just need to learn more about the wiring diagram and such, that way it might not take me as long to get something done hahaha
Steve
Lodi , Ca |
phatsat67
Ha yeah, working on these old ones sure is a good time.
caricoa28
So I got the boat back about a week ago and shes running smooth. Very smooth in fact. New carb works great, and i wont know if she still boggs out at high speeds until i get her back in the water. The boat place still didnt put on the starter that I paid for, in fact they put on an OEM starter instead. They said they couldnt find a high torque for my motor that would work.. And it just so happen that they "forgot" to tell me. I call BS, but none the less the owner and the mechanics all agreed that after my ***************ty experience with these people, that theyre just going to send me a refund for the starter and call it a day. Wow fine with me. So now its on to gauges.
Steve
Lodi , Ca |
Steve,
Sorry to hear about your problems. Yes, there are plenty of so called "mechanics" out there that really don't know whats up! Keep us in mind if you ever need to find parts. There are several sources for starters and in fact, Nautique Skins (Christines- site sponsor) just posted starters on sale. |
Chevy350
Gold Member Joined: June-24-2013 Location: Illinois Status: Offline Points: 721 |
We ordered the wrong starter once, it fired up on land so we dropped it in the water and cranked it till it died. We sucked water in though the exhaust and into the engine. We ended up getting the water all out and floated it onto the trailer, fixed the old starter, changed the oil, and winterized it. We un-winterized it this year and it seems just fine. So you should be good.
1972 Mustang
