1999 SN EFI Question |
Bri892001
Posted: June-05-2015 at 12:34pm |
According to Joel, 11 posts down in the following thread, a partially failing low pressure fuel pump can start to draw too many amps, which will trip the 15A breaker:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=25584&PN=1&title=poor-mans-gt40-diagnosis |
Orlando76
Look for a loose connection and or corrosion at starter/breaker/solenoid.
jhersey29
Senior Member Joined: February-20-2014 Location: Colorado Status: Offline Points: 272 |
Red.fuse? Do mean circuit breaker on the back of the motor? Which one of the 3? It only trips when the starter is pulling amps? If that is the case I would check all the wiring to the starter. Possibly a short.in the starter or faulty starter wire.
Wormcat1
Newbie Joined: March-18-2015 Location: United States Status: Offline Points: 20 |
What would cause my red fuses to keep tripping on my 1999 SN EFI Box? Sometimes have to reset them 2 or 3 times before boat will start?? Maybe a bad fuel pump or something is clogged? Thanks for any help....
