  New Posts New Posts RSS Feed - The 1979 Ski Tique Resto-Mod Story
dwouncmd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwouncmd Quote  Post ReplyReply Direct Link To This Post Posted: May-21-2015 at 9:57pm
Looks good on the water...
89 SN
<a href="http://www.correctcraftfan.com/diaries/details.asp?ID=6567&sort=&pagenum=1" rel="nofollow">7
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: May-21-2015 at 11:43pm
It does look good on the water but cut it out till you check your timing or you may spend the rest of the summer looking at those pictures and wishing you hadn't blown it up.
rosconole View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rosconole Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2015 at 2:10am
MINT!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-22-2015 at 9:19am
+1
LeftFieldEngineering View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeftFieldEngineering Quote  Post ReplyReply Direct Link To This Post Posted: May-29-2015 at 10:34am
Letters came out pretty good considering I used $17 vinyl, a laptop, projector and an x-acto knife to cut them in place.
As with the rest of the boat it's meant to take a beating. Once setup I traced 3 sets of side graphics, one for each side and an extra in case I loose a letter along the way. Provided they stay put I plan on spraying some shadowing with the air brush to give them some depth like the metal panels.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeftFieldEngineering Quote  Post ReplyReply Direct Link To This Post Posted: June-20-2015 at 8:35am
Mid Summer Update:
Skiing:
As planned I stared pulling for the local ski club. I drive 1-3 nights a week, everybody loves the boat & I love driving.
Lessons Learned:
Running out of gas sucks. According to my trusty bummin-stick we had 2/3 of a tank. Normally this have been fine, the 3 of us would ski 1 - 2 sets, get tired and call it a day. What I didn't account for was more friends showing up. With 2 more skiers we ran a few extra sets and on the last run she sputtered out 300 yds from the dock. Thankfully, sitting level in the water the pickup was able to find some fuel and we idled back to the dock. Needless to say I'm going to keep a better eye on it. Also I'm super disappointed there's no reserve tank on these boats. I mean is it that hard to put a 2nd pick up in the tank and a switch behind the seat? I considered installing on myself when I had the tank out, but didn't want to f-around with a fume laden tank.
Maintenance:
She still warms up during 2+ minuet barefoot runs, reading around 200 on the dash, however using an IR thermometer I'm getting 175-180 at the intake manifold and 125-130 at the water pump so I'm just going to keep an eye on it in the future. For a little piece of mind I did pick up and install an over temp / low oil pressure alarm. Pretty cheap insurance policy at @ 25 bucks.
I'm also investigating a rear main seal leak. If I run the boat in the water for 1+ hr I will get a little oil dripping from the bellhousing. For now I've just put some PIG oil-only sorbent pads in there to sop up the drippage.   I'm about 1/4" - 1/2" high on the dip stick (ya I accidentally overfilled it) not sure if that's factoring into it or anything, but it seems to only drip if were out on the water. Perhaps the steep motor angle of the Tique + the angle of the boat when pulling young skiers at 12-18 mph is resulting in that extra 1/2 quart sitting against the rear main? Idk it's a shot in the dark theory. Anyway unless it gets worse it's a winter fix.
My points are damn near shot. I have new points, condenser, cap & rotor sitting on the work bench. As soon as my dewll meter arrives they'll be getting swapped out
Upgrades:
I'm looking at installing a new speedo. The no-name brand one I installed Sucks. It reads 3-7 mph fast depending on how fast your going. I feel bad pulling skiers at the club and having to SWAG the speed all the time. I dug out & cleaned up the original air guide yesterday and I plan on giving that a shot this afternoon. I hope to narrow down if its the gauge or the pickup. Even if it's just the pickup I'm probably going to swap it out for a gps unit at some point.
Chevy350 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chevy350 Quote  Post ReplyReply Direct Link To This Post Posted: June-20-2015 at 10:46am
Glad to hear you're enjoying the boat, Today will be my first time out for over 2 weekends.
Have fun and be safe!
1972 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeftFieldEngineering Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2015 at 9:16am
July Update:   She's working great & I'm enjoying every minuet of it!
Problems, solutions & upgrades:
Miss under load when hot: A few weeks ago I noticed that towards the end of ski club (2+ hrs of driving) the motor would drop a cyl or miss under load. Ended up being the coil, it got replaced in no time.
Bad speedo: Originally I wanted to clean up the dash so I picked up a no-name brand dash mount speedo and replaced the factory airguide. I had luck with a similar speedo on a previous boat so I thought nothing of it. Turns out the speedo would read 2-5 mph different across the sweep. Pulling dozens of skiers a night this was unacceptable. I picked up a in dash GPS unit (Faria 33726 Chesapeake) from Overtons, with an internal antenna it was a breeze to hookup. Plus the blue matches my Teleflex gauges so it blends right in.
Seats: Unlike it’s big-boat counterparts my Tique came with 2 single seats, one for the driver & one for the spotter.   I was content with the 2 single seats until I saw some pictures of Tiques with a tiny rear facing bench, this got the gears turning. With foam, vinyl & plywood left over from my last boat project I was all ready to whip up a bench seat when I had a thought to Google “24 inch bench seat”. To my surprise I found one from BoatSeatStore.com for $120.00. I picked up a 24" benchseat + matching driver seat, shipped to the house for just under $195. They’re no factory sets, but they look pretty damn good if you ask me. My favorite part about the universal seats is they fold. I’m not particularly tall or skinny so hurtling the fixed-back driver seat or squeezing between the pylon and the seat back was a PITA, now I just fold down the seat and step right over it. Also having the spotter seat fold means easy access to the storage space under the dash. Again for 195 bucks I couldn’t be happier.
Lastly – Budget Ballast:
“Hey are those pool bags in your boat?”
“Damn right, I don't have the money for those fancy ballast bags."
When it came to adding weight to the boat I didn't want to spend the money on oversized fat sacs, plus I knew I had seen water bags somewhere else. One day it clicked - POOL COVER BAGS, I had filled dozens of them helping my grandparents close their in-ground pool as a kid. The 4ft bags weight between 45 & 50 lbs and can be easily moved, stacked or positioned in the boat to shape the wake depending on what we’re doing. 2 bags up front to keeps porpoising to a minimum while footing, 4 bags on the driver side helps level out the boat when footing on the boom, and 4 bags on each side of the engine cover adds an extra 400 lbs of weight for wakeboarding. Not bad for 30 bucks, plus if one gets a hole in it you only lose 5-6 gallons.
I fill them using a modified 3 gallon bucket; the bucket has a 1” PVC bulkhead fitting with a section of reinforced hose. Press the pool bag bung onto piece of hose, dip the bucket in the lake and in 30 seconds you have a 45lb weigh bag ready to be the boat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2015 at 8:12pm
I sure hope you picked up a tube while you were there. They without a doubt are the tube experts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeftFieldEngineering Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2015 at 8:32pm
Didn't need to, already a member of Overtons Tube Of The Month Club.
Kristof View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kristof Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2015 at 4:29pm
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2015 at 4:48pm
... I picked up a in dash GPS unit (Faria 33726 Chesapeake) from Overtons, with an internal antenna it was a breeze to hookup. Plus the blue matches my Teleflex gauges so it blends right in.
These GPS speedos are a nice option. I believe they'll be a helpful part of the solution for owners experiencing the 2000-2001 gauge cluster problems.
I definitely enjoy the GPS speed readout on the my Perfect Pass.
Fabcon View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Fabcon Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2015 at 5:57pm
1976 Ski Nautique 351 Escort
1984 Barefoot Nautique (Parting Out)
GMacLaren View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GMacLaren Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2015 at 10:41am
My GPS Speedo is great.
One shortcoming is it shows speed over the ground, not through the water.
So, if you're skiing on a river, readings are sometimes not very helpful.
-=Grant=-
-=Grant MacLaren=-
Retired Expert
http://www.grantmaclaren.com/72skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2015 at 7:41pm
-=Grant=-
Grant,
How fast is this river running you boat on?
Post Options Post Options   Thanks (0) Thanks(0)   Quote GMacLaren Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2015 at 8:38pm
On the Mississippi at the Alton Pool, my log shows GPS speedometer read 15 mph at 1500 RPM going downstream; 2000 RPM required to maintain 15 mph upstream. Not sure of river's speed, but I'll guess 4 to 6 mph.
On the St. John's Cruise (FL), I'll guess 4 near Sanford. Of course it depends on many variables:
I think you'll find current speeds at U.S. Geological Survey websites, but then they're kinda hard to use for calculations while towing.
-=Grant MacLaren=-
Retired Expert
Post Options Post Options   Thanks (0) Thanks(0)   Quote GMacLaren Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2015 at 8:39pm
. . . esp. when it's raining.
-=Grant MacLaren=-
Retired Expert
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2015 at 8:44pm
Once you have an idea of what RPMS correspond to what speeds in still water, you can use your tachometer as a guide.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2015 at 9:01pm
Please don't run at 1500rpm in any river or any lake or ever. Thnx!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chevy350 Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2015 at 9:05pm
What could happen?
1972 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: July-29-2015 at 1:30am
What could happen?
A wake the size of texas that sends a never ending trail of rollers for one.....I see it all the time on our little pond....and it drives me crazy!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chevy350 Quote  Post ReplyReply Direct Link To This Post Posted: July-29-2015 at 8:18pm
What could happen?
I thought it was bad for the boat... oops. I'll make sure to never do it.
1972 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeftFieldEngineering Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2015 at 7:17am
What could happen?
Could be bad for your health too
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeftFieldEngineering Quote  Post ReplyReply Direct Link To This Post Posted: May-27-2016 at 6:51pm
Interior Update - New skins for doghouse & rear seat
New Skins
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: May-29-2016 at 1:59pm
Looks sharp
