  New Posts New Posts RSS Feed - mpi conversion
mpi conversion
doug e View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doug e Quote  Post ReplyReply Direct Link To This Post Topic: mpi conversion
    Posted: December-16-2006 at 5:53pm
Can anyone recomend the best way to convert to mpi on a carbed 2005 chevy 350
Cheap thrill fishing team
boat dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Posted: December-17-2006 at 1:50pm
Doug, Sumitt has several kits to convert to MPI tho very pricey.Accel offers a complete kit for 2595.99,s/b Chevy; 2795.99 s/b Ford. Includes ECM,pump,manifold,all parts to make your carb go away. Sounds kinda pricey to give you instant start,fuel usage wont change much.
Holley has a kit also,but they have a lot of gotta haves with their system.
go to Summit.com and look at what is available..............boat dr
Post Options Post Options   Thanks (0) Thanks(0)   Quote doug e Quote  Post ReplyReply Direct Link To This Post Posted: December-17-2006 at 2:52pm
I spend hours at a time live bait fishing at very low idle and it seems that the carb. motor has a hard time at that. will efi or mpi help for this And is there a differance between efi and mpi
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Posted: December-17-2006 at 6:23pm
Doug,Electronic Fuel Injection,is a mechanical way to induct fuel and air into an engine.The two popular ways are Multi Port Injection and Throttle Body Injection.One uses one injector for each cyl, a more complicated but better way ,TBI uses a throttle body and common injectors ,usualy 2 to accomplish fuel distribution.Its just a high tech carb,with no fuel bowl.
Sounds like a carb problem ,a new carb would be far cheaper,S/B Ford 302 ,mine,loves the Holley 450 CFM, will idle for hours at 500 rpms.............boat dr
Post Options Post Options   Thanks (0) Thanks(0)   Quote doug e Quote  Post ReplyReply Direct Link To This Post Posted: December-17-2006 at 6:27pm
yea, I think my carb is a rodchester quadro-jet 850(too big). Thanks for all your help I think a new carb is the way to go!
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: December-18-2006 at 6:58am
Originally posted by doug e doug e wrote:
yea, I think my carb is a rodchester quadro-bog
Found your problem
River Rat to Mole
