NautiqueParts.com2025 Calendar Photos
  New Posts New Posts RSS Feed - Weep Holes
Weep Holes
jwweathers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jwweathers Quote  Post ReplyReply Direct Link To This Post Topic: Weep Holes
    Posted: July-09-2015 at 10:01pm
I noticed a very small amount of rot in my stringers inside the weep holes. My plan is to scrape out the rot and seal the holes? How should I seal them??
Thanks,
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-09-2015 at 10:09pm
Jeff,
The water moisture is already in the wood. You will not be able to seal up the wet wood plus the water has penetrated deep into the stringers. It will never dry out. Sealing up wet wood is not a good idea since it just creates a great environment for the rot spores. When fiberglass hulls first came around and including CC, the wood stringers were simply "tabbed" to the hull. The tabs were just strips of glass laid over the tops and to the hull. many of these are still around since it allowed the wood to dry. You ether leave the wood open to dry or you TOTALLY encapsulate/seal with a CPES method.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jwweathers Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2015 at 4:12pm
Makes perfect sense. Thanks for the great tips!
Jeff
