  New Posts New Posts RSS Feed - Air Intake , Throttle body ?
HudsonSpeeder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudsonSpeeder Quote  Post ReplyReply Direct Link To This Post Topic: Air Intake , Throttle body ?
    Posted: October-23-2004 at 11:33am
Hello,
Being fairly new to the Nautique family I would like to know where and how does the FRESH AIR intake (to the carburator) get to the engine ? I have been involved in the Automotive Racing and increasing the Air Intake flow makes the engine perform better. I have wondered why the Marine engines don't use a DIRECT air intake like K&N or something of this nature. Not that I would do it because it would just look awful but there must be a way to get a better cold air to the intake. Thanks
___________________
Nautique 1992
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: October-25-2004 at 1:55pm
Basically, the air for the engine comes from the air forced into the bilge via the air scoops or intakes on the bow deck of the boat. The vent fan forces airflow via the same bow vents and exits the air to the stern vent. While underway, the air is forced in and out without help.
So, I suppose you could fabricate a direct attachment to one or part of the bow vents. Just make sure you leave the spark arrestor in place and also leave enough air flow through the bilge to clear out fumes and heat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudsonSpeeder Quote  Post ReplyReply Direct Link To This Post Posted: October-25-2004 at 4:59pm
Thanks. This will be my winter project to see how I could improve cold air to the intake.
Hudson
___________________
Nautique 1992
jimbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimbo Quote  Post ReplyReply Direct Link To This Post Posted: October-25-2004 at 5:46pm
I think it's a great Idea. It gets pretty hot in that tiny engine compartment, not to mention you can't move as much air through the compartment as you do in your car at highway speeds. The boosts in hp in automotives are pretty good and that's based on a relatively cooler engine compartment. Good luck!
502 Python View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 502 Python Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2004 at 12:18am
Keep us posted on your cold air induction package.It sounds like a great idea.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudsonSpeeder Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2004 at 11:56am
Hi 502 Python,
The nautique is now at rest for the winter as we should see snow as soon as next week. I have spoken to some of my friends in the Racing world and we have a some real good ideas. When spring comes I will be putting things together and will post here.
Have a great Winter!
Hudson
___________________
Nautique 1992
WRoll View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WRoll Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2004 at 1:45pm
Question: What results are you expecting? In racing every 100 of second counts...
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudsonSpeeder Quote  Post ReplyReply Direct Link To This Post Posted: November-18-2004 at 2:14pm
Hi WRoll,
Good question. I'm not really expecting any HP or performance gains , but the engine is getting older and I believe if the air intake is cooler engine life will be prolonged. The other benefit is at higher RPM the engine will run cooler. I am not a mechanic but this seems pretty logical to me. Why I started to investigate this avenue is because on a very hot day if I ran the Nautique at 4400 RPM for longer than 5 minutes the temperature would raise to over 200 degrees. Yes this is OK but if you drop the temperature even a little the engine stress will be reduced.
Am I wrong?
Thanks,
Hudson
___________________
Nautique 1992
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: November-19-2004 at 12:11pm
I'm not sure if there would be any real benefit. There are realy only two ways to feed cold air in to the intake, run a hose from the front scopes to the carb or cut a hole and add a scope to the motor box. It seems to me that you have a restriction in the raw water pick-up. I can run mine at 5500+ rpm all day long and not see over 180 degress or 10 degress over normal operating temp. If I do see the temp increase more than that then it is time to clean the sea strainer, If you don't have one you need to install one.
Bill336 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill336 Quote  Post ReplyReply Direct Link To This Post Posted: November-19-2004 at 1:18pm
I agree with 79Nautique. Cooler air in the engine compartment won't do much, if anything, to cool your engine. The air really doesn't have much time to heat up at higher speeds anyway if you think of the engine as a big air pump. It pulls a lot more air than you would think. A friend put some ram air boxes around his spark arrestors on some big HP engines and vented them under his rear bench seat. With 4 5" rigid hoses feeding air directly to 2 550 HP engines, he said it sounded like a vacuum and had to build another box around them so nothing would get sucked into the carbs.
First I'd check your seawater pump for a worn impeller or a restriction at the trans cooler. I just bought a 78 CC and the guy said that it had been running hot before he bought it. I pulled the intake hose off the trans cooler and it was full of what looked like chopped up seaweed. A worn impeller will show up as higher temps too, until it completely fails.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudsonSpeeder Quote  Post ReplyReply Direct Link To This Post Posted: November-19-2004 at 1:38pm
Thank you for very good info. I replaced my impeller this summer , but I haven't checked the intake to the trans cooler. I think you guys are right ,maybe all the work needed to have a proper air intake (that might work) is not worth the trouble and noise I will have.
Thanks for the good tips,
Hudson
___________________
Nautique 1992
