  New Posts New Posts RSS Feed - Temporary vinyl repair
jhersey29 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhersey29 Quote  Post ReplyReply Direct Link To This Post Topic: Temporary vinyl repair
    Posted: July-16-2015 at 5:45pm
I'm waiting on a few skins from Christine's and my back seat rest is getting worse by the day. I'm want to save the foam but am at that point where the foam is so exposed it may need replaced. Will duct tape suffice until I can get the skins. They are pretty far behind and are terrible at returned calls about vinyl eta and status. Seems like really great people but obviously buried. I took home ec instead of shop for the girls and dad tought me enough about shop that there wasn't much of a need for shop classes.   Maybe my sewing skills could start a new business as there is clearly plenty of work to be had Jk!
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2015 at 6:14pm
Like Grandma's couch, a clear plastic slip cover. If duct tape maybe just tape visqueen to the remaining vinyl, would not want it sticking to the foam if it could be avoided.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2015 at 6:30pm
Seen lots of duct tape used but it makes a huge mess. Take it out if you're that worried about the foam getting destroyed.
M3Fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M3Fan Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2015 at 6:37pm
Based on my experience this is apparently the case for everyone involved in the boating industry. The car industry isn't much better! Pretty amazing, really.
2016 SN 200 OB 5.3L DI
https://forum.fifteenoff.com
storm34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2015 at 7:05pm
+1 on what Joel said. Had the same experience w/Christine's, Local companies and a few buddies have struggled with other local companies.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2015 at 7:12pm
Get some cheap vinyl locally & just cut/sew the corners for a slip fit over the old skin. Put in a few staples for good luck. Don't leave it on f0r too long otherwise mildew will have a field day.
74Wind View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 74Wind Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2015 at 7:33pm
+1
If it's hot wherever you are the backing glue on duct T'ape can turn into a slimy mess.
just sit on a towel
1974 Southwind 18
1975 Century Mark II
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2015 at 7:52pm
The leather in my truck especially the drivers side decided to dry out and split several years ago. I slipped canvas backing between the skins and the foam and then used fabric glue. It's been working great
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhersey29 Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2015 at 7:21pm
Tried duct tape with failure. The glue didn't go everywhere but it didn't stick at all. After trying and coming out to remove cover the next day it all had just shriveled up and fell on the floor. Went with $5 of marine vinyl from Jo Ann Fabrics and tried to iron it on. The iron on stuff seemed more like a hold in place while stitching something together than a good adhesive. It would work fine on cloth but didn't stick well to the vinyl. I cleaned the vinyl with MEK and ended up using 2 coats of Permatex Heavy Duty Body Shop Headliner and Carpet adhesive on each piece waiting 5 minutes between coats and then 5 minutes before connecting the 2 parts. If I had more hands it would have gone on straight but once the contact happened it wasn't going to budge.    Not bad for a hack job. Thanks and also to my friend Tim for his thoughts.
This should save the foam until the skins arrive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 74Wind Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2015 at 8:42pm
You must have a big swim platform to be able to install that galley on it.
1974 Southwind 18
