  New Posts New Posts RSS Feed - Test your CC/SN knowledge
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2015 at 2:47pm
Originally posted by 74Wind 74Wind wrote:
Originally posted by T_bone19 T_bone19 wrote:
RECAP
Potential causes
1. Closed cell foam is damaged and has absorbed water ( 80% believe this the culprit)
2. Engine Mis-Alignment ( 15%)
3.. Extra material on the boat or in compartments (4 %)
4. The boat was seized off the coast of Key west and $20MM in illegal product are between me and 4 inches of fiberglass. (1%)
#4 just wishful thinking? Too bad DeLorean didn't make boats...
Now I'll have to find my old "Save the Bales" t-shirt...
We found Jimmy Hoffa.
1976 Ski Nautique 351 Escort
74Wind View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 74Wind Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2015 at 3:25pm
so much for The Meadowlands...
1974 Southwind 18
1975 Century Mark II
KRoundy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2015 at 9:43pm
And we still wait for photos...
As the owner of a composite stringer boat - the idea that 1/2 of the boat is waterlogged is 100% doable. I had a huge crack in my floor under the observers seat and that area was filled with wet foam. All the holes drilled in the structure are potential areas for water ingestion: bolts that hold on the engine frame, screws that mount side rails, brackets for seating, the trim ring around the pylon.... There are holes everywhere.
The only way to actually check for wet foam in these boats is to cut a hole in the floor.
T_bone19 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T_bone19 Quote  Post ReplyReply Direct Link To This Post Posted: July-26-2015 at 9:58am
RECAP
Potential causes
I took pictures yesterday, with an empty tank of gas, removed all items from the boat, and ensured the no water was present in the boat.
I checked the airbox - Nothing abnormal found, just speaker, 2X hoses for the heater.
Gas Tank Removed the center floorboard and checked all around the Gas tank and i could not see anything abnormal or any additional material
I also measured with level as someone suggested in a previous post
Facts
The Boat List to Starboard by a solid 2" inches
The weight seems to be most noticeable in the middle to stern of the boat.
Takes 200 pounds on the far port side to level this boat out
Nothing i can see in the airbox or around the gas tank that would add this much weight.
you can see the waterline is at the Ski Nautique decal ( This isn't the water level)
Post Options Post Options   Thanks (0) Thanks(0)   Quote T_bone19 Quote  Post ReplyReply Direct Link To This Post Posted: July-26-2015 at 10:07am
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: July-26-2015 at 12:07pm
So Quinner nailed it.   10" way too optimistic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: July-26-2015 at 12:25pm
Tyler, the 2" was the amount under the straight edge, correct? If so that means one gunwale 1" high, the other 1" low. And was the 2" the total over the whole beam of the boat?
I'll check mine today just for the fun of it. Different hull, but I'm curiuos if it sits level.
Post Options Post Options   Thanks (0) Thanks(0)   Quote T_bone19 Quote  Post ReplyReply Direct Link To This Post Posted: July-26-2015 at 12:32pm
2" total on each side I.e 2 low and 2 high.
I'm starting to think it's wet foam. Not sure how much money that will cost
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRoundy Quote  Post ReplyReply Direct Link To This Post Posted: July-26-2015 at 1:00pm
The materials are not difficult or expensive to purchase, and it is a very easy job to do --- it just takes time. It is relatively cheap to do yourself and expensive to pay somebody else to do it. Would be a lot easier if you were to pull the engine to do the job.
Or - just leave it as-is. You have no wood in there to rot, so the water is not hurting anything (if that is what it is). I doubt that makes much difference when the boat it under way.
And by the way - nice looking boat! Welcome to team blue/grey.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: July-26-2015 at 4:31pm
Your picture taking and posting skills could use some work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-26-2015 at 4:46pm
I just turned my laptop upside down!
Post Options Post Options   Thanks (0) Thanks(0)   Quote T_bone19 Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2015 at 3:47pm
Any thoughts ?
M3Fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M3Fan Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2015 at 4:01pm
Any thoughts ?
Two options:
1. Rip up the carpet and floor and look for wet foam. Remove, re-glass, re-carpet
2. Throw a 50 lb weight on the far left under the spotter seat and stop worrying about it.
Mine has almost the same lean and I've owned it for 9 years. I shred buoys and glass behind it and I haven't really let it bother me.
2016 SN 200 OB 5.3L DI
https://forum.fifteenoff.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2015 at 4:13pm
Still waiting on interior pictures. Under bow, behind panels, etc.
Spent some time on scoots python this weekend and it sat level at the dock. Had a boom under the observer seat and 1/2+ tank of gas but otherwise unloaded.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: July-29-2015 at 1:31am
Big ladies love boat rides.
1968 Ski Nautique, Project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: July-29-2015 at 12:23pm
You would know ^
Mojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mojo Quote  Post ReplyReply Direct Link To This Post Posted: July-29-2015 at 12:34pm
Any thoughts ?
Two options:
+1
05' SV211 TE
73' Martinique
had:96' SNOB
had:76' Nautique
had 77 Tique
LeftFieldEngineering View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeftFieldEngineering Quote  Post ReplyReply Direct Link To This Post Posted: September-21-2015 at 2:24pm
Any more news on this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote T_bone19 Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2016 at 10:01pm
UPDATE - Final Verdict
Had the dealer drill a hole at the back and check the foam .
Good News: Foam is not waterlogged no waterlogged foam in the boat
What's causing the list
Engine is about 1" or less off Centre to starboard side, the big block would have enough weight for that deviance to give the list.
Check with Manufacturer - Nautique
"By design, deal with it ".... Nautique expressed that this is a normal and common place in those years of the SN. As long as the boat is level underway it was deemed acceptable.
Had dealer check/confirm that the propshaft came out of the port straight and it does.
There is no side to side adjustments in mounts for this...it is structurally stringer placement on assembly,
Cost me $$$ for Nautique to say by design deal with it.
File a formal a complaint with Nautique and I am currently in discussion with Greg Maloon. He did re-confirm their position and performance criteria of SN at the time of manufacture was for the boat to be level at skiing speeds( 34-36mph)
He has forwarded my complaint to C/S, not expecting much. However, i must say i was impressed he responded to my email in fairly short order. Like I said to him this is where the prop hits the water.
Stay Tuned,
Cheerio
Tyler
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2016 at 11:29pm
Tyler, I wish you luck but it's a 17 year old boat that you bought just last year. Seems like a stretch to expect the manufacturer to repair it for you.
Glad to hear that Greg was responsive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote T_bone19 Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2016 at 11:42pm
63 skier - Just a point of clarification
There is nothing wrong with the boat that needs repairing, so your point is a little misguided
The issue is the boat was not manufactured properly and they deemed it appropriate. The boat is a defect and should have been recalled. No different than a car recall, your car can be 20 years old and it gets recalled.
"Rest assured we stand behind our products...Live without compromise" Greg Maloon, CEO Nautique
Tyler
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2016 at 11:48pm
So if nothing needs to be repaired, what do you want them to do for you?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2016 at 12:37am
17 posts in Joel nailed it Wish you luck but I don't think you have a leg to stand on. Boats 17 years old,your not the original owner and the boat has not been recalled. A recall is for safety issues which this is not. I would think this is more of a manufacturing defect that the original owner either didn't realize or care.
Post Options Post Options   Thanks (0) Thanks(0)   Quote T_bone19 Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2016 at 1:02am
LoL...Tell me something I don't already know, I think your right.
At the very least I was able to find some information and details about a rare boat that I didn't know and passing it along with all of you.
Thanks for all the interest in this post
Tyler
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2016 at 1:39am
Tyler, no need to get defensive. As you saw from the responses, people here genuinely wanted to help you get to the bottom of your problem with the boat. And I don't mean to offend you with my question, just seems to me a tough argument to make that the manufacturer still has to do something about this.
As for a fix, if the stringers are not symmetric and placed incorrectly which puts the engine off center, there isn't a side to side adjustment in the mounts to compensate for that. What baffles me a bit with that conclusion is if the strut/stuffing box are properly on center, how did they get a shaft to align with a motor an inch off center?
Post Options Post Options   Thanks (0) Thanks(0)   Quote T_bone19 Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2016 at 1:46am
I think you have misunderstood my post and my tone. Perhaps I could have put a lol at the end of it.
Just paying the info forward.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2016 at 1:54am
Sorry then, my mistake!
I did look back at Joel's post (M3Fan 17th post down) and he said there is some side to side adjustment? I didn't realize that. I'm still not clear how it could align if that far off center.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2016 at 7:39am
What happened to Tyler's pictures? Have they been removed? Can anyone see them?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2016 at 10:42am
Mine has almost the same lean and I've owned it for 9 years and I haven't really let it bother me.
Many like Joel don't let a slight list bother them!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2016 at 11:40am
There IS side to side adjustment in the motormounts, that's needed for alignment.
It doesn't matter where your stringers are (even if off center), if the engine is aligned you're good to go. There could be a chance the strut and log are way off the centerline causing the list but nobody seems to be checking for that.
Other than you saying the list was more pronounced at rest we still haven't seen any 34-36mph list evidence.
So far there is nothing wrong with this boat, just the current owner. "lol"
