75 separator rebuild |
Post Reply | Page 123 15> |
Chevy350
Gold Member Joined: June-24-2013 Location: Illinois Status: Offline Points: 721 |
Posted: August-04-2015 at 10:23pm |
Any on water videos?
1972 Mustang
Smithfamily
WOW!!!
Js
Beyond chine walking is running on the lower unit cavitation plate. Been there once and you have zero control.
JPASS
An example is here.
'92 Correctcraft Ski Nautique
skutsch
Justin;
When you are flying these boats (because essentially that is what you are trying to do, get as much boat out of the water as possible), they end up tettering on a relatively unstable portion of the boat because so little of the hull is in the water. In the case of the Bass Nautique (an most vee hulls) their is a 10 inch wide pad (flat spot) on the bottom of the hull, here is a picture of the Bass Nautique Pad: I don't think the Seperator even has a pad that is this wide if it has one at all. The object is to trim the boat so as little the boat is in the water as possible. Here is a picture that illustrates that, as you can see, only about 12 to 18 of the aft end of the hull is in the water: As you go faster, this becomes very unstable, especially with the Seperator as it continues to rise out of the water. Chine walking begins when you "fall off the pad" or the boat leans to one side. When it does this it eventually finds the water and for lack of a better term "bounces" (it's actually more of a the hull hits the water planes off) and starts leaning the other way. It now has force that it comes back up on the pad and then immediately goes over the pad to the other side, "bouncing" again back in the first direction. If left un-corrected this will continue until the boat goes so far over that it hits one of the chines, catches and "hooks" or makes a very sharp uncontrollable turn, usually ejecting anyone in the boat. VERY dangerous condition. If you are quick enough and experienced, you can counter-steer when it starts to fall off the pad, boat falls to the right you steer to the left (to pick up the right side of the boat), this is how you "drive through it. Otherwise you have to ROLL off the throttle smoothly (remember with an outdrive,(power gives you control -there is no rudder, so you can't chop the power) and trim down the drive. Joe and Tim's boats also do this, Tim's more then Joe's as the Barefoot also has a deep-vee, instead of the flatbottomed ski nautique. Any boat will chine walk (well except for a tunnel hull) when you start to operate it where it gets unstable. |
connorssons
DrStevens
Senior Member Joined: October-15-2011 Location: Columbus, OH Status: Offline Points: 422 |
Geez Jeff, that is wild!
Don't sell yourself short Steve, yours was set at an official event so your still champ until the next one Justin chine walk is when the boat rocks from side to side. I was talking to a neighbor who had a Switzer craft his did the same. One of the Switzer brothers showed him how to drive past that, once he did went another 10 mph |
Side to side movement typically with a yaw. |
Chevy350
Chine walking?
skutsch
Well I had the fastest correct craft for a while, get a GPS on that thing to capture the real speed.
When you switch to the 26 the same thing will happen but at lower RPM. Chinewalking hits me at 70, and I have TONS of RPM left in the motor. I also need to figure out how to drive it. I was hitting 70 mph with a 26p at 6800 RPM and the chine walking would start. With the 24p I would get the same thing at 70mph, but RPM's were just above 7000 (who has time to look at the tach or GPS anyway...). Get some video too, and screen shots of your max GPS speed. |
connorssons
Well, ran sep today, 5400 rpm 22 pitch prop med trimming hit 80 on the speedo, not gps,ed. Started chine walking, backed her down. Need to lean how to drive this thing now, gonna change prop 26 pitch and see what happens next!
74Wind
Wow
Like most, I'm typically not an I/O guy, but I have a weakness for I/O thru-hulls. With that look and sound somehow this one's like evil incarnate, bravo, well done! |
1974 Southwind 18
1975 Century Mark II |
samudj01
Gold Member Joined: March-10-2009 Location: NC Status: Offline Points: 974 |
Any chance of an October Badin Lake Mini showing???
Orlando76
I like the coyote.
connorssons
Breaking in motor this morning, ran it to 3000 rpm boat is at 60 mph with a 21 pitch prop gonna run it gently some more this afternoon, will video it. Acceleration is unbelievably quick
Fabcon
Gold Member Joined: August-27-2012 Location: Buffalo. Mn Status: Offline Points: 554 |
Very nice
1984 Barefoot Nautique (Parting Out) |
storm34
Bri892001
That's awesome
DrStevens
Outstanding, let me know when I can get a ride!
fanofccfan
Platinum Member Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1778 |
Very nice.
JPASS
Good God man she sounds awesome.
connorssons
https://www.youtube.com/watch?v=J1-UQumbbu4
Here is a hyperlink for the video, and here's another link for a better picture. http://s1189.photobucket.com/user/Misketty92/media/IMG_2375.jpg.html?sort=3&o=0 |
Chevy350
That sounds so mean. Now I'm waiting for the water test. But 500 HP??? That's insane!
1972 Mustang
connorssons
Chevy350
Any updates on this? I've been dying to hear it running.
1972 Mustang
Bri892001
Jeff, you have video of it running? If it's video, the only way to easily share it, is to upload to Youtube first, then share the youtube link on here.
connorssons
What a great idea, im trying to make it happen.
lewy2001
Take trailer with boat and phone to GL and I am sure someone will show you how to do it |
