  New Posts New Posts RSS Feed - No Fire
No Fire
starbucksdad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote starbucksdad Quote  Post ReplyReply Direct Link To This Post Topic: No Fire
    Posted: August-21-2015 at 9:21pm
After my engine gets hot and I shut it down usually will not start. What is mostly likely to fail when hot, coil, points, condenser? Definitely getting fuel.
starbucksdad
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2015 at 9:29pm
Most likely issue is it is getting too much fuel and is too flooded to restart - cranking with the throttle held wide open would start it and confirm that to be the issue. If that isn't the issue or you have used a tester to verify you have no spark come back for the alternative theorys.
Post Options Post Options   Thanks (0) Thanks(0)   Quote starbucksdad Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2015 at 9:38pm
Tried throttle, does not help
starbucksdad
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2015 at 9:43pm
Holding the throttle wide open, no pumping, no bumping, just wide open and cranking the crap out of it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote starbucksdad Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2015 at 9:49pm
Tried that
starbucksdad
Post Options Post Options   Thanks (0) Thanks(0)   Quote starbucksdad Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2015 at 9:57pm
Remember this only happens after engine is hot and been running for an hour or so.
starbucksdad
LeftFieldEngineering View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeftFieldEngineering Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2015 at 10:08pm
If your concerned your loosing spark hook a timing light up to one of the cylinders. If your getting spark the light should blink, if it doesn't your not getting spark. Let it cool down and see if the light will blink.
Post Options Post Options   Thanks (0) Thanks(0)   Quote starbucksdad Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2015 at 10:11pm
Thanks but by the time I get back in and do all that it will start.
starbucksdad
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2015 at 10:54pm
Take the light with already hooked up
a0128 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote a0128 Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2015 at 11:43pm
Are you sure it is not a vapor lock? Sounds like once it cools off it starts up again.
If money can't buy happiness, explain beer and boats.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2015 at 11:54pm
Here we go again!!!
