  New Posts New Posts RSS Feed - How much pressure?
How much pressure?
91NaughtyQ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 91NaughtyQ Quote  Post ReplyReply Direct Link To This Post Topic: How much pressure?
    Posted: August-27-2015 at 11:25am
I took a first past last weekend at wet sanding / buffing etc... The end result was good, but not where I want it. As this was the first time I was conservative and only used 2000 grit paper.
This round I am going with the incremental approach starting out more coarse as suggested in the FAQ.
Questions -
1. How much pressure is applied? Is it a light rub or do you give it some elbow grease?
2. Do you only sand in straight lines or do you alternate with circles.
Thanks in advance..
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: August-27-2015 at 11:31am
Steady, light to moderate pressure, use a block at 600grit and coarser. Straight lines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 91NaughtyQ Quote  Post ReplyReply Direct Link To This Post Posted: August-27-2015 at 11:34am
Perfect! Thanks. Now for the fun...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: August-27-2015 at 12:50pm
You can always remove more, not less...
Alternating directions will help to know when you've cleaned up the scratches from the previous round.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 91NaughtyQ Quote  Post ReplyReply Direct Link To This Post Posted: August-27-2015 at 1:00pm
Gotcha. Thanks.
1991 Ski Nautique
(Previous)1984 Ski Nautique 2001
backfoot100 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote backfoot100 Quote  Post ReplyReply Direct Link To This Post Posted: August-27-2015 at 1:29pm
Agreed but a caveat to this is be careful. If you feel high spots, which you will, sand around those by hand or you'll soon be through the gel if you persist with the block. At least in my experience.
Eddie
