  New Posts New Posts RSS Feed - Transmission fluid overfill
knewt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote knewt Quote  Post ReplyReply Direct Link To This Post Topic: Transmission fluid overfill
    Posted: August-27-2015 at 11:28pm
Hi,
1984 Ski Nautique - 351 Ford - Velvet Drive transmission
Noticed my transmission was slipping last night so I let it cool down and checked the fluid this evening. It is about and inch higher than the top fill line on the stick - so somehow fluid leaked into the system.. I can't tell really for sure but it appears to be extra water in there - light red in color and very less viscous.
I am assuming my transmission cooler has a leak.
Has anyone ever seen this? I am assuming it is an easy fix/replace.
1980nautique View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote 1980nautique Quote  Post ReplyReply Direct Link To This Post Posted: August-28-2015 at 12:13pm
Kent,
if the water level in the bilge didn't get high enough to enter the transmission, through a poorly sealing dipstick or plug, then the cooler is leaking. Skidim and others have them for $80. The trans should be flushed, engine running with no trans load 2-3 times with Dexron. Velvet drives are very forgiving. Hopefully it didn't lose pressure and friction long enough to require a rebuild.
Post Options Post Options   Thanks (1) Thanks(1)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-28-2015 at 8:06pm
Kent,
I agree with the cooler being the potential problem. Pull it out, apply about 30 psi to the oils circuit and stick it in a bucket of water looking for bubbles. That will confirm or rule out the source of the water.
