Electrical Issue Continues |
SteveHookEm
Senior Member Joined: July-17-2015 Location: Houston Status: Offline Points: 157 |
Posted: September-19-2015 at 11:07am |
So I had my stereo installer replace the cable from the battery to the ignition with an 8 gauge wire. We went out yesterday and as soon as we turned on the stereo again, the engine surged, almost died, continued to run but ran rough. I killed it and then it would not start again. No ignition light at all either.
So I opened the battery compartment and the installer had wired in a 20A fuse between the battery and the dash. I didn't ask for that! I called from the lake dead in the water and he said they wanted to put something as a protection between the battery and the ignition. Is this normal? Floating out there I had to cut out the fuse and twist the wires together. The boat ran fine after that. However, I do not get the red light for ignition anymore until the key is turned. I used to be able to push in the button and the light would come on before turning the key. What causes that? |
Steve,
Yes it is normal to fuse or breaker any load from the source. If there's an overload or a direct short, the overload device will open the circuit protecting that circuit. Worst case without an overload device, there could be a meltdown or even a fire. Since the fuse blew, there is certainly a problem. Get the VOM out and find out what's going on. To avoid confusion as well as everyone getting the complete history of your problem, I highly recomment you continue the issue in the original thread you started. |
SteveHookEm
Is a 20A fuse too small? And he said that the wire he pulled out that was 10 gauge was a straight shot from the battery to the dash with no fuse. I'm certain that was the factory wiring.
Should the stereo be directly connected to the ignition or should it go through an accessory button? I don't know what a VOM is! |
SteveHookEm
I'm thinking that the fuse blew because 20A wasn't enough to run the electrical needs while the engine was running and the stereo turned on
Steve,
The factory feed to the dash would be fused at the dash rather that at the battery. If he replaced the factory feed with the 20 amp, then it is quite possible it isn't big enough. Someone needs to add up the amps and it's sounding like this "installer" is not the person to handle the project. Not knowing exactly what he has removed and added, makes it difficult to diagnose the problem. If you have a hard time with electrics, find someone else besides this "installer" who can help. In your other thread is a link to up grading the dash feed. Properly done, this means BOTH the positive and negative. A VOM is a volt ohm meter. |
I did same thing & fused the new + wire for the dash power, so naturally I think it is a good idea.
IIRC, I used 30 amp fuse. I used this info to select the size according to wire size: max amps |
Bri892001
Sounds like the installer may have replaced the original wire feed going to the key, with a direct (fused) line from the battery. And, then still wired the stereo off of the key switch.
Stereos typically have/want/need two power sources, One, is a constantly live source, which keeps the clock and presets going. I believe this is also the stereo's main power. The other source, is ignition switched power. This should just be the signal that tells it to turn on and off. He should have had the stereo's main, constant on, power feed go direct to the battery. Basically then, left everything as far as supplying the key switch alone. Then, have the "switched" power source for the stereo go to the ignition post on the key. Even better, have the switched power source go to an available accessory switch. That way the key (and your hour meter) don't have to be on to make the stereo power switchable. |
Bri892001
I may have been mistaken with the constant on power source being the main source. It may be that the switched power source is the main source for the radio.
Either way, it would be better to supply the stereo directly from the battery, and not try to tap into the key wiring, which really isn't equipped to handle the load in this case. |
SteveHookEm
It's fixed again but haven't been out yet to test since I'm waiting on a new prop to arrive. This time, he put a 60A glass breaker on the 8 gauge line from the battery to the dash. He put the stereo on Accessory 2. So we can listen to the stereo now with the engine on or off by having the ignition switch pushed on and Accessory 2 on. Will that still affect my hour meter at all? Does the hour meter run when the ignition button is pressed in or when the key starts the engine? |
Bri892001
The hour meter only runs when the actual key switch is turned to the on/ignition position, whether or not the engine is indeed running.
If it uses the ignition push button breaker and an accessory switch, you should be in good shape. |
Did he or anyone determine the true load? It has crossed my mine several times that this guy doesn't know WTF he's doing!!! With the 8 ga. protected at 60A, he's way past the amp capacity of the wire. Have you checked the charge on you fire extinguisher lately? |
Bri892001
The OEM push button breaker for these is 20amps. The stereo, worse case scenerio should pull about 10ams, but probably more like 5-7 typically.
So, I'd ballpark it around 30 amps total max. More than 20 but less than 60 |
SteveHookEm
When we had a 20A fuse in line, it blew immediately when I turned on the stereo while running. The stereo worked fine while just sitting with the engine off.
Now that the stereo is on Accessory 2, I don't think I'll have any issues. |
Steve, I sure hope you don't have anymore problems. The point I was trying to make is no one with any electrical knowledge/ability, over sizes wire protection devices. In your case, it's a factor of 2!!! This guy must have come out of the back yard hack school of sound system installation. I wasn't kidding about checking your fire extinguisher. |
Pete you beat me to it.
But actually, when you consider that the OEM wiring is semi-protected by the oversized 50A breaker (on engine), it isn't any more dangerous than CC sent from the factory. The saving grace is that the hull isn't conductive, so a break in insulation isn't as big of problem as on a car. |
bmenge
Newbie Joined: July-19-2011 Location: Cedar Rapids Status: Offline Points: 10 |
Hey guys,
I am having the same troubles. When I turn my radio on with other accessories my voltage drops way down to a point where my radio will cut in and out. What is the main cause of this issue? Ground? Power source? Wire gauge? Daisy chain system behind dash? Quick connect plugs? Should I eliminate all daisy chain and run all wires to bus bars? Or just ground? Should radio get powered directly from battery or should everything? Can radio run off accessory switch instead of key? Should I run thicker positive and negative feeds? Sorry for the 20 questions. I have been dealing with this problem as long as I have been a CC owner. My dad's 88 Ski is in far worse shape wiring wise than mine and it has been since we bought it. I am not afraid to do the work for this, if rewiring the whole dash is the solution then that's what I'll do. Just looking for some input on the best solution not the easy one. Thanks, Brian |
Yes to all questions above. Except if you run a heavy gage hot & ground wires to buss bars, no need to also run stereo from battery, just use the buss bars. Fuse everything appropriately.
It is a good upgrade & your boat will thank you for it. |
Brian,
I totally agree with Chris. |
SteveHookEm
Problem solved. Ran the boat Saturday. Stereo works perfectly with the motor on or off.
It is now connected to Accessory 2. No power to the stereo unless that button is depressed. Only remaining little item is that my red light next to the ignition button does not illuminate when the button is pressed until the key is on. Before, I could press the ignition button and see the light to know it was on. I'm afraid now the button will be left pressed and run down my battery. No idea why that changed! The light is not burned out. It comes on when I start the engine. |
Sorry Steve but I strongly believe that putting a 60 amp fuse in is NOT solving a problem. |
Bri892001
Don't worry that the ignition breaker itself is going to run down your battery. That alone won't. Shutting it off, guarantees everything else on that circuit is also off, but just that being on isn't using power. The ignition breaker is like plugging and unplugging a table lamp. If the lamp is switched off, it's not using power, Taking the additional step of unplugging it from the wall isn't going to make it use even less power. If it's switched off, the circuit is broken, and it's off, end of story. As far as the change in behavior of the indicator light, that may be due to a nuance of of the wiring change. It's hard to say. If you have the breaker on, key off, but then switch on something else like the bilge, blower or horn, what happens with that indicator light? I'll have to look at mine carefully again, but I don't think my ignition breaker indicator light goes on, unless something else is also turned on on that circuit. |
The indicator light's ground must have gotten broken somehow.
