1988 STRUT BUSHING |
Post Reply | Page <123> |
D&C1988
Groupie Joined: February-16-2015 Location: TableRock Lake Status: Offline Points: 67 |
Isn't there a Zach guy that has come up on several posts here that works at a dealer.
Does anyone know if they could - would do the replacement? I am into this by myself and doing it in a unheated garage. Not a lot of interested helpers and my wife wants her parking space NOW. All 3 of our cars are outside and it's frosting. |
David, Do check again for the set screws although for removing the old cutlass, backing them off isn't needed. For removing the old, assemble your hacksaw with the blade down the middle of the bushing. Carefully cut through the brassouter shell. A couple places may be needed. Don't worry if you nick the strut slightly. Take a punch to the brass shell and curl in inward on itself. The old show come out. Yes, explore the site some more. The FAQ thread in this section is an excellent source for info. |
74Wind
Pete: that he couldn't find anyone interested to work on it is no surprise. Betcha if he had a newish pricy boat it would be no problem...I had once inquired all around ATL on some potential work to be done. When I told them the model year they all quickly blew me off....including the Nautique Dealer....
1974 Southwind 18
1975 Century Mark II |
a 5 gallon bucket full of empty beer cans makes a nice rudder catch
Yes, need to remove, not 'drop' the rudder (have a 2nd person handy). Not hard to do & you can grease & adjust packing while at it.
Use a socket & long screws to press out coupler. Only turn screws 1/4 turn each time so as not to distort flange. |
backfoot100
Of course you are correct. Complete brain fart on my part. I just find it easier to pull the engine but I have a hoist system that makes it easy. |
Eddie |
have you tried doing any site searches? your questions have been answered many times over
google "strut bushing site:correctcraftfan.com/forum" |
D&C1988
OK, 2 things. Are we sure there are no set screws in the strut. I have wire brushed the sides and see NO dimples where there might be a set screw. Second what do I use to press the shaft out of the coupling and is there enough wiggle room to leave the rudder on?
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21183 |
No need to pull the engine, just press the shaft out of the coupler.
D&C1988
I will most likely never have to do this again while I own the boat. At least that's what I am hoping. There was a lot of regular maintenance that was not being kept up when we got it. I knew it, but we bought it anyway. Part of the story. We were able to use it all last summer with fluid changes and not beating on it. Every time I got some extra money I bought parts with the hope of being able to do a lot of the work over the winter.
backfoot100
Sorry. I was actually trying to quote Tim wondering why not just remove the shaft if it's good.
Eddie |
backfoot100
That's exactly what I was wondering. The only issue being the engine needs to be removed to remove the shaft in that scenario. Still easily accomplished with some ingenuity and worse case renting a lift. Still WAAAAYYYY under $350 and only needing very basic tools.
Eddie |
This is the unknown. |
Duane,
I've got a another thought on the ARE that you are planning on making. Put some wrench flats on the coupling itself. It will help when torqueing the nut to seat the shaft to the taper. Also, you may already know but inside the bore of the coupling are fine threads for the removal nut that is screwed in to push the shaft out of the taper. |
Why does he need a new shaft? While the ARE system is nice, if the existing shaft is fine, just remove it, replace strut bushing and reinstall. Some bolts/threaded rods/nuts, socket, oven and hack saw are all the tools you need. Half day effort, 2 people to handle the reinstallation of the coupler is advised.
Put the $350 into the gas tank. |
Duane,
It's the taper connection at the trans coupling. The R&R is easy compaired to heat shrinking the interference fit coupling on a single taper shaft. Sound like you are going the make your own. Great but I do have a suggestion. After you machine your tapers at the coupling, do lap them. Even the ARE's need some lapping. Due the limited space, the taper is a short one making the taper fit very important. |
Duane in Indy
Pete, Please explain to me the big advantage of the ARE over the stock system. Hate to do all the lathe work if there is no big gain. Thanks, Duane |
David,
Since you can wiggle the shaft in the cutlass, I confirm it's time for a new bearing. No one in your area services DD boats? Wow, it must be keeping the I/O manufacturers happy! As mentioned, we are all here to get you through the cutlass swap. I had a forman one that when confronted with a statement something like "I don't know how to do it". would always come back with saying "you can learn something every day of your life and still die stupid". I as others have mentioned, spend the money you had figured for the Strutpro on the ARE system. It's well worth it. |
D&C1988
Yes I have watched some You-Tube. You all have successfully talked me out of buying the strut pro tool. However my $350 offer still stands until if figure it out. To answer the question about the shops, I keep hearing we don't get into direct drives. About why I am changing, Pretty sure 95%+ it is original and there is enough play I can see it when I grab the drive shaft and wiggle it. Since I spent the money on a new prop and there is some vibration during launch seemed like the right thing to do. Yes I can get some pictures posted, and I planned to put it in the diaries section with the back story on how my wife and I ended up with this specific boat.
David,
No one has asked but what makes you feel the cutlass needs changing? Is the shaft sloppy in the cutlass? Do you know when the last time an engine/shaft/strut alignment was done? A cutlass lasts for many years but with bad alignment it doesn't take long to trash them as well as other parts. How about posting some pictures? |
JPASS
Hollywood's right. And if you run into trouble, you have this site to walk you through it. |
'92 Correctcraft Ski Nautique
David,
What are these places telling you as to why they don't want to replace the cutlass bearing? You say you don't have the knowledge our skills to undertake the job and yet it sounds like you watched some hyped up video demonstration so now you can do it? MANY of our members have taken on jobs they haven't done and been successful. We are always around if help is needed. |
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2972 |
If your'e going to spend the money, I'd recommend an A.R.E. double-taper drive shaft instead of a bearing removal tool. The double taper shafts can be purchased at skidim.com or nautiqueparts.com. Pulling the shaft is the biggest challenge with the strut bearing change-out. With the shaft out, the strut bearing removal/installation is a snap.
Just my 2¢ (adjusted for inflation) JQ |
drop the rudder, push off the coupler, remove the shaft, replace the bushing yourself with a hacksaw blade, bake the coupler, reinstall everything
not a single expensive tool required, i'd be you already have everything needed. |
D&C1988
Guy's, I hear what you are saying. My problem is knowledge and experience. I am sure I have enough tools to go old school but I have no way to fix anything I mess up in the process. I have tried every boat dealer within a 100 miles of my house and no one is interested. I can't even get a price. If there is anyone close to STL that has replaced a cutlass, and knows what they are doing, I'd pay you the $350 cash.
^ which is only $65 more than the strut tool. This may not save you time or increase performance but your old hardware has value as a back up or sold
David,
John is correct that the "tool" isn't worth the money.
Just picture taking a slide hammer to a piece of brass tubing with a .035" wall thickness. The contact area is even less than the .035 since it needs clearance to the ID of the strut. You can't pound rubber! It may work half way decent once but then your "business" plan would suffer. Do you really believe everything you see on an internet youtube?? If you don't have an ARE shaft system, this would be a great time to install one! |
mark c
Yes, the OD of an 88 SN cutless bushing should have a dimension of 1.25", a length of about 6" , and an id of just slightly over 1".
Can't give you exact length of the bushing because I have two shorter non-metallic bearings installed on my 87 (which is the same as an 88) but my original one was just about flush with the front an rear faces of my strut, at most maybe 1/4" shorter on each end.. |
D&C1988
Not really trying to start a business. Just not drop $350 on a one time use tool. Thought someone else might like to use it too. I have a prop puller already. Got it with my new #542. Still need to confirm the cutlass size?
baitkiller
Don't bother with the tool and business plan. Its not a hard job with basic hand tools, and frankly, the tool doesn't work that well. Spend the $ on a decent prop puller that you can share with your friends.
