Chrysler 318 part out |
wwchevy
Senior Member Joined: August-22-2011 Location: Michigan Status: Offline Points: 369 |
Posted: August-21-2014 at 10:43am |
318 Engine Components for sale. I will make deals on multiple parts and shipping will be an extra $10.00 on smaller items
Alternator-SOLD Carter AFB 4bbl Carburetor, Flame arrestor & cast iron Wedge. Needs rebuilding- $40.00 SOLD Trans Cooler - $50.00 SOLD Sherwood dual pocket raw water pump & Pulley- $50.00 SOLD Engine & Trans Mounts- $65.00 Chrysler Distributor w/ adapter for block and clamp- $30.00 |
wwchevy
1989 Barefoot Nautique |
wwchevy
LH Rotation 318 Chrysler Marine engine- Sold on Craigslist pending payment. The rest of the parts I have are still for sale. I updated the first post with photos
wwchevy
65Cuda
Groupie Joined: September-28-2012 Location: Matthews NC Status: Offline Points: 97 |
do you still have the water pump?
wwchevy
I do, $50.00 plus $10.00 shipping.
wwchevy
Fletch
Newbie Joined: September-07-2015 Location: Forestville Status: Offline Points: 1 |
I would love to buy that distributor with adapter and clamp for my 64' barracuda. I just fried the same one testing out the new stereo. Live and learn I hope. Please let me know if it is still available.
dago52
Newbie Joined: December-01-2015 Location: texas Status: Offline Points: 5 |
do you still have trans&engin mounts ? thanks james
fanofccfan
Platinum Member Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1743 |
If he does not I may have some. Let me know if you want me to look.
dago52
what i need the most are the rear trans mount.the ones i have are rusted so bad you cant ajust for the main shaft line up. than you for the reply. James
James, Welcome to CCfan. How about some pictures? I don't mean to break up a sale but many here find the same rusted condition typically when they do a engine/trans/shaft/strut alignment. What they do is remove the mounts (which you need to do anyway) disassemble and clean them up. Looking at the picture of the mounts above, I'd say you would need to do the same with them!! What are you working on? Tell us more. Are you doing an alignment? |
dago52
iam restoring a 1963 wiliamson with 440 chy. with 330 hp. i will send picks. when i get back to rockport. James
wwchevy
Sorry, but I didn't see the response to this old thread. I don't have any more Chrysler parts. You will have to buy them from Bill or follow Pete's advice or do both. Sorry I can't help. Good luck with your project.
wwchevy
Do post pics of your engine mounts. 63 would have been too early for a 440 with 330hp as an original engine, don't make it any less cool just a little information for you. I cant remember if the Chrysler mounts for the big velvet drive were anything special but I am certain even if they are I have a pair or two around if yours cant be saved with a little elbow grease.
fanofccfan
I agree with Pete and Joe on this one......yours can most likely be grout back to life. I assumed you did not have any at all. If I can find mine they would probably need the same elbow grease as yours..
dago52
i tried to free up the mounts,but thay where to for gone.down here with all the salt its hard to find good used parts. Ill keep looking. thank James.there is a pic. of my boat ..on web site www.williamboatworks.com.look on our history.the small boat on the bottom is like my boat.
James, I'm curious as to what methods you tried to free up the mounts. Did you remove them from the boat as mentioned? |
dago52
i removed from boat,then heated with torch,also diped in used oil
James,
I don't feel the used oil did anything since it's viscosity is too high. The proven penetrating oil that many here have had fantastic results with, is a home brew of 50-50 acetone and ATF. The ATF has lots of detergents for lubricity and the acetone thins it down for penetration. Is it the threaded section that's locked up? After soaking with the penetrating (it may take several days) I'd take the impact to it working it back and forth. |
Anything can be freed up but with salt it might not be worth it- again if you can find a pic there is a decent chance I have something around that will work. |
