Teleflex Amp gauge / Volt meter? |
62 wood
Posted: July-06-2013 at 8:43pm |
Steve,after we talked I was curious how they work and found out some have springs to keep the needle centered. I wonder if one broke or came off. Have you shaken it to see if anything inside makes noise? It might be worth a call to Dale to see what he thinks and to make an appointment
62 wood
I cant really tell that anything is loose inside.. I'm thinking I need to get on Dale's "list".
I'll look and see if I've got one from our Skier.
Mojo
Steve, I've a few gauges for ya. I'll bring them to GL with me.. Moj' |
aobrian
Newbie Joined: December-09-2015 Location: Rochester NY Status: Offline Points: 3 |
Hi,
I'm looking for the same style gauge. I need an amp/volt and a temp gauge. Any chance you know where I can get these? Thank you! |
DrCC
I have two that don't work Steve. I replaced mine with a brand new Teleflex - S/W style face. I'd call Dale and see how many years it would be to put your face on a new gauge.
WOOPS !!! sorry, didn't notice the 2013. But anyway Steve, did you find a solution ??? |
74Wind
I found a set of original guages on ebay or craigslist, can't remember which, have you looked there?
1974 Southwind 18
1975 Century Mark II |
aobrian
Yes, I found the rest of my set...just missing volt & temp. Do you know a good gauge restorer? I have the old ones if they can take the old face and put it in a new gauge.
74Wind
Amp will be harder to find than volt, mine is amp, volt requires different setup
1974 Southwind 18
Here is a great gauge repairman. None are cheap,Dale is slow but does excellent work. He would be worth the call. I'll see if I can dig up any of Johnb's posts on his repair.
Here are a couple of before and after of Johns gauges |
62 wood
I did find an solution.... I came across and installed an NOS Dixco amp gauge. It looks almost identical to the original Teleflex. In fact there are 2 or 3 like mine one on ebay right now.. Dixco Amp Gauge I have since found an NOS / original style Teleflex Amp gauge that is tucked away for a "when I have nothing else to do but replace gauges" - day. ohhh, I also found a nice used blue stripeTeleflex volt meter as well... just in case I want to do some re-wiring some day. . |
aobrian
Any chance you want to sell your used volt gauge???
The swap from amp to volt is an easy one. The simplest way is to bond (join) and insulate the two wires that were on the amp gauge together. Then wire the + terminal of the volt gauge to the switched side of the ignition switch and then the ground terminal to a dash ground. BTW, it's my opinion that an amp gauge gives you a truer reading of what's going on with the boats electrics. Manufacturers went to volt gauges simply due to cost. As amps went up requiring heavier gauge wire, so did costs. |
